Opel Corsa C Windshield Washer: Voltage Issue, Severe Frost, Transmitters & Damaged Cables
anzelmus 5121 2
  • #1 16252503
    anzelmus
    Rate: 13
    Hello, in my corsie c the windshield washer stopped working after a very severe frost. from the wipers the relay is knocking and there is still no voltage on the washer plug, the cables look damaged. I have a question whether the transmitters that are pressed into the panel are removable and whether there may be some reason under it.
  • #2 16252530
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    The fact that the relay is knocking does not mean that it gives voltage to the motor. First you need to check the voltage at the output from it.
    If it is and there is no plug on the plug, the cable is damaged.
  • #3 16252582
    anzelmus
    Rate: 13
    I replaced the relay from the rear wiper because both are the same, they are next to each other.
    Added after 5 [minutes]:
    I am also interested in the panel in which these transmitters are, whether someone has already pulled it out because there are two latches on both sides, I tried to pull it out, it slips out a bit from these latches and it does not go any further. I would not want to break something if I am not sure.
