Sony KDL40R450B - Turns off after a time and the red LED blinks 6 times.
oborniczek11 8640 6
  • #1 16254379
    oborniczek11
    User under supervision
    Help: 17
    Rate: 54
    Tv, as in the topic, turns off after a while and the LED blinks 6 times.
    Can run 6 hours trouble-free.
    Does anyone have a bug list for this tv or know what the code means.
  • #3 16255105
    oborniczek11
    Help: 17
    Rate: 54
    I was looking for my problem in google.pl, but I did not find my model of error codes.
  • #4 16255333
    Polon_us
    Help: 1184
    Rate: 1280
    From what I read on the Sony forum, the 6 blink code refers to dusty or clogged air outlets in the TV housing.
    In other words, the TV is overheating and thus signals a problem.
  • #5 16258329
    oborniczek11
    Help: 17
    Rate: 54
    Cleaning the TV did not help anything, after 20 minutes the symptom is about the same.
  • #7 16263814
    Elektrona
    Rate: 14
    The matrix highlighting turned out to be damaged.
    Matrix illuminated with LEDs the same as, for example, in the camera flash in a mobile phone. I did not think that these diodes can burn.
    For me it is strange that the LED is damaged.
    I wonder if it's not a marketing gimmick sometimes.
    Incorrect current and voltage for the diode, which makes its lifetime short.
    The video from your link shows that you can insert a plain white LED with a resistor from 100 to 330 ohm. In my case, I put a smd Led from a flashlight with a 100 ohm smd resistor. Checked with 24v power supply.
    However, after connecting and assembling the TV does not work.
    I try to start the TV 3 times and then the LED diode flashes red 6 times.
    When you try to turn on when you turn on the backlight, you can see the replaced non-original LED as it shines with a stronger light than the original ones.
    My guess is the wrong resistor.
    I ordered a backlight from a new TV with a broken matrix.
    As I mention, I will write about the effects.
✨ The Sony KDL40R450B television experiences shutdowns after a period of use, indicated by the red LED blinking six times. This issue is commonly associated with overheating due to dusty or clogged air outlets. Despite attempts to clean the TV, the problem persists. Additionally, there are concerns regarding potential damage to the LED backlight, which may be exacerbated by incorrect current and voltage settings. Users have discussed the possibility of replacing damaged LEDs with alternatives, but issues remain unresolved, as the TV continues to exhibit the same blinking error after repairs.
