GOODRAM CX300 128GB SSD: Speeds Max 350Mb/s on ASRock 970DE U3S3 & AMD Phenom II x4 955 Setup
KABAN_DG 4284 5
  • #1 16254997
    KABAN_DG
    Rate: 15
    I bought an SSD yesterday to speed up Windows - it fell on the Polish Good Ram CX300 128GB design.
    I watched various tests and it performed very well in this price range.
    My hardware is the Assrock 970DE U3S3
    AMD Phenom II x4 955 3.2 GHz
    RAM GOODRAM DDR3 GR1333D364L9 - 4GB
    I decided to test the ATTO DISK disk. There is a video on YTube where during the test the maximum speeds reach up to 499 Mb / s when saving (I attach the file).
    For me it is max 350 ... and now I wonder if this is due to some defect in the disk or the equipment. The disk is of course connected to SATA3 and has the latest drivers for that port downloaded. I don't know if I have a basis to advertise a disc?
    • GOODRAM CX300 128GB SSD: Speeds Max 350Mb/s on ASRock 970DE U3S3 & AMD Phenom II x4 955 Setup yt.jpg (159.91 KB) You must be logged in to download this attachment.
    • GOODRAM CX300 128GB SSD: Speeds Max 350Mb/s on ASRock 970DE U3S3 & AMD Phenom II x4 955 Setup cx300.jpg (146.46 KB) You must be logged in to download this attachment.
    rzymo
    Help: 206
    Rate: 322
    Hardware faults, specifically the ASMedia ASM1061 controller (motherboard / chipset does not have native SATA3 support). Transfers at the level of 360-380MB / s are the norm for him.
    Kasek21
    Help: 4981
    Rate: 3547
    Everything is OK.
  • #4 16256552
    KABAN_DG
    Rate: 15
    Thanks for explaining ...
    I know that the disc is old, etc., but in my opinion it is misleading ... or marketing halt ... why mount SATA 3 and write in specifications up to 600MB / s - since it is known that it will not reach speed :)
    However, apart from this, the difference in work is colossal compared to HDD :)
  • #5 16256560
    Kasek21
    Help: 4981
    Rate: 3547
    In the case of SSD, transfers are of secondary importance - what makes using the SSD so pleasant to use a computer is the time of access to data.
  • #6 16256697
    KABAN_DG
    Rate: 15
    Thanks for the help, subject to close
