GOODRAM CX100 SSD Not Booting, Slow Connection, CRC Error, RAW Partition & Reduced Capacity
marekdb9 3795 2
  • #1 16165998
    marekdb9
    The GOODRAM CX100 SSD refused to obey me and the system does not boot. I wanted to connect it to another computer so that I could dump data from it. The first time I connected the drive was very slow, there was practically nothing to be done on it. After reconnecting it threw a CRC error and showed a raw RAW partition, on the third it was no longer visible in the system at all. When I checked the status in the CrystalDisk program, nothing appeared in it, only ... 2 MB of capacity (the disk is 120 GB).
    Is there any home way to repair / recover data or do I have to throw the hard drive away and buy a new one? I had the disc only 11 months. It is true that there is a guarantee, but I do not have a proof of purchase or a receipt for it, and it will probably not be recognized.
    Could the failure be due to the drive overheating too much? The laptop usually operated in temperatures in the range of 70-80 degrees.
  • #2 16166279
    laptokowiec
    Help: 112
    Rate: 120
    This model often does.
    Data recovery probably possible and maybe less than PLN 1000
  • #3 16166915
    michal_aniol
    Help: 182
    Rate: 100
    This drive model usually came with a PS3110-S10-X or PS3110-S10C-12 controller. These controllers have not been developed yet - I mean the chip-off method.
