LTE Plus Internet Poor Performance: Antenna Placement, WiFi Issues, and Suggestions
dziekanm 1932 3
  • #1 18547036
    dziekanm
    Hello. I have the same problem with Plus internet. Roof antenna wifi in the house
    LTE for 3 lines. Antenna mounted about 8 meters above the ground. I moved it to the chimney because I thought it was poor. It works so poorly that I can't do a speed test, the speed downloaded on the 12-25kbps modem page. When I started the youtube movie, it reached 600kbps
    I will add that I am not an IT specialist and I do not understand the launch of this LTEWatch program
    I am asking for any suggestions.
    Moderated By dt1:
    Please, don't add your problems to someone else's thread. We help his Author in someone else's thread.
  • #2 18547484
    pitron
    Help: 51
    Rate: 100
    If you have a huawei router then you can play LTEWatch, otherwise you can approach something using Network Cell Info. In general, LTE in the netflix era is a misunderstanding.
  • #3 18547664
    dziekanm
    I have an IDU-200 router and the one on the roof is an ODU-200 external modem
  • #4 18548230
    matek451
    Help: 4352
    Rate: 5808
    Screen show of LTE status on IDU200, where do you use this pseudo LTE from Zygmunt on this crap? In addition, do the test outside on the Plus card but on the LTE phone with Android and the application https://play.google.com/store/apps/details?id=cz.mroczis.netmonster and show a screenshot of it and the result of the speed test.
