Brother DCP-J105 vs Epson WF2630 vs HP PHOTOSM 5520 vs Epson wf3620
lucaa44 7002 14
Which of these home MFDs is best if I want cheap ink cartridges and protection against the printhead drying out?
The Brother DCP-J105 is the best match if your priority is preventing the printhead from drying out; users recommend Brother because it periodically refreshes the head even when the printer is switched off, as long as it stays plugged into the socket [#16529043][#16531074] That protection uses only a small amount of ink, and one user says the DCP-J105 is the successor to the DCP-J315W, which had no head problems even with long idle periods [#16531074] The downside is that the refresh can happen automatically and you cannot schedule exactly when it runs, so it may occur at inconvenient times if the printer is left plugged in [#16531074][#16530825] For consumables, several replies warn against the very cheapest replacements; better-quality replacements such as ORINK or Actis were suggested, and one user said they had good results with replacement inks around 4–6 PLN each plus periodic cleaning fluid every 2–3 months [#16529043][#16556673]
  • #1 16520171
    lucaa44
    I plan to buy an MFD for the home.
    After searching the "what to buy" section, I selected 4 models that suit me best: 1) Brother DCP-J105 [520pln, new] 2) Epson WF-2630WF [390pln, new] 3) HP PHOTOSMART 5520 [290pln, allegro, new, 12 months seller warranty] 4) Epson wf-3620dwf [PLN 500, new].
    This choice was primarily influenced by the fact that all 4 devices have cheap carcass replacements available, followed by a reasonable price for the devices themselves.
    The dcp-j105 is in favor of a mechanism that prevents the ink from drying out (I care a lot about the chosen device having or at least using the ink cartridges integrated with the printhead) ... for the rest of the devices I don't know if they have such mechanisms (apparently hp use ink cartridges integrated with the printhead).
    Which device of these 4 would you recommend?
    Thanks in advance for any help
  • #2 16520180
  • #3 16520355
    lucaa44
    @ krzysztof212, do you know how dcp-j105 (or j100) comes with cheap carcass replacements (from a well-known auction site), is it troublesome or is everything alright?
  • #4 16521698
  • #5 16528638
    lucaa44
    @ krzysztof212, before you wrote back I found information ( here ) that dcp-j105, however, accepts cheap replacements..what to the replacements themselves - a cheap replacement does not always mean a shorter printer life ... opinions are divided on the forum ... I used cheap Canon Canon for 5 years and nothing bad happened. It was only a six-month break in use that made it (the trail got hit because the ink went dry).
    back to dcp-j105 - I am interested in this mechanism that prevents the ink from drying out ... how it looks in practice - it happens to you that it turns on at night itself and wakes up all household members ;) ? does it turn on only during the day?
    Regards
  • #6 16529043
    wsiur
    Brother has been using automatic cleaning in printers for a long time, even if it is turned off, all it needs is that it is plugged in. Cleaning can happen. It is obvious that ink is consumed.
    I recommend brother, but I would not use the cheapest substitutes (they can beat the head), but some better ones. In slightly older brothers I use ORINK companies and I have no problems.
  • #7 16530176
    lucaa44
    the cheapest replacements for dcp-j105 are tempting with the price - for a ...... 5pln / pcs ...
    in the well-known online store from Krakow there is a large selection of cheap replacements (but not the cheapest ones compared to a ......) ... which the cheapest from this store would you recommend to dcp-j105 (tfo, incor, actis or maybe other )?
    I repeat the question: how is this automatic cleaning in brother dcp-j105? can turn on at night and wake up the household (this printer is quite loud) ??
  • #8 16530483
    dr.master
    Help: 518
    Rate: 927
    Loud is not ...
    I recommend starting cleaning the head from the user's menu in a friend's shop / store and checking.
    I also have a private brother, and even vigilant household members do not arouse ...
  • #9 16530825
    wsiur
    One client got scared at night because she thought it was a thief or a mouse, but it was an older model for 985 carcasses. As far as I remember the newer ones are quieter so that the sleeper will not wake up. I would turn it off at night because it won't dry for 10-12 hours.
  • Brother head refresh runs even when powered off
    #10 16531074
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    You would have to pull the plug out of the socket, power the printer. Brothers have a refreshing of the print head (because it is not cleaning, it is only refreshing, "protection against drying out") works even when the printer is turned off with the On / Off function button, all you have to do is plug the printer's power plug into the socket and it's enough that there is no problem with the head, the only drawback is that there is no option to set when it is to "space". It does it when you "remember" it, we have no influence on it, maybe in newer models there is an option to set this function, I don't know. Ink this option consumes minimal and yet protects this head. I've been using the DCP-J315W Brotcher for several years, I print very little (sometimes this month is "useless", only the plug connected to the socket) and there has never been a problem with the head I use a replacement ink for Actiwe Jet - the price for a set of cartridges (4 colors) from about PLN 40. Brother DCP-J105 is probably the successor to the Brotcher DCP-J315W.
  • #11 16535984
    lucaa44
    and what do you think about those inks for j105 that I replaced (tfo, incor, actis)? anyone uses them / used for j105? if so how does the printer respond to them?
  • #12 16536068
    dr.master
    Help: 518
    Rate: 927
    When it comes to replacement inks, they won't cost you a zloty.
    It is worth investing in empty ink and occasionally release the cleaning fluid for cleansing the heads.
  • #13 16538212
    lucaa44
    as long as they don't cost PLN 1
    I understand that you mean, for example, these inks: 5949328820 or 6580781845 (no on a well-known auction site)? ... although zlotys do not cost, but they are also very cheap
    release cleaning from time to time
    can you specify how often? once every six months, a month or more often?
  • Cheap refill inks and periodic head cleaning
    #14 16556673
    dr.master
    Help: 518
    Rate: 927
    Once every 2-3 months it is enough.
    I used a very cheap replacement at my place, 20 containers for PLN 30 (PLN 1.5 each) and I saved 3 heads ...
    It seems to me that 4 - 6 PLN for ink is a reasonable price and rinsing with cleansing liquid every 2-3 months and you can print virtually free.
    You can also buy a set of empty large inks and inks in bottles and dilute them with cleansing liquid. It comes out very economically and there are no problems remembering to unblock the heads.
  • #15 16657143
    lucaa44
    Finally, I was tempted to dcp-j105, I have been testing it for a week and I am honestly average.
    I describe my current printer problems here .
    Thanks again to everyone for your help.
The discussion revolves around selecting a multifunction device (MFD) for home use, specifically comparing four models: Brother DCP-J105, Epson WF-2630, HP Photosmart 5520, and Epson WF-3620. Users express a preference for the Brother DCP-J105 due to its ink drying prevention mechanism and availability of affordable replacement cartridges. Concerns about the longevity and performance of cheaper ink substitutes are raised, with recommendations leaning towards using original or higher-quality replacement inks to avoid damaging the print head. The Brother printers are noted for their automatic cleaning feature, which can operate even when the printer is off, although it may consume some ink. Users share experiences with various replacement ink brands and their effectiveness, emphasizing the importance of regular maintenance to prevent clogging.
