[Solved] What inkjet multifunction device with wifi and duplex to buy?
bodzio.c 4542 10
Which inkjet multifunction printer with Wi‑Fi and duplex should I buy for up to PLN 600 if I want cheap inks?
The thread leans toward a Brother multifunction printer, especially the T700W or another model from the T300/T500/T700 series, because Brother is repeatedly recommended for cheap running costs and refillable ink tanks [#17308120] [#17328287] The T700W is described as a bit over budget but offering more benefits, with a factory refill system and 3 years after product registration [#17308120] Another reply lists durable Brother models such as 625DW, 725DW, 825DW, 925DW, 6510DW, and 6710DW [#17444896] One user chose the Brother DCP-J105 for budget reasons and cheap replacement inks, but noted that it has no duplex [#17490841]
  • #1 17308070
    bodzio.c
    Rate: 20
    Hello colleagues. My "Brother DCP-145C" (error 4F) just fell after 9 years of trouble-free operation and I'm looking for something new. It must be a printer + scanner + copier, of course color with wifi, very willingly with duplex and cheap inks, for up to PLN 600. What colleagues think about BROTHER DCP-J562DW POLSKIE MENU, DUPLEX, WIFI. Maybe some other suggestions?
    best regards
  • #2 17308120
    dr.master
    Help: 518
    Rate: 927
    If a colleague appreciates cheap operation, then only Brother.
    We dilute the carcasses in the bottles with the cleaning agent. For this permanent ink tanks and you can continue printing for free :D
    A little over the budget of the T700W, but there are many more benefits.
    3 years after registering the product on Brother's website and the factory refilling system ...
  • #3 17309158
    sdfwffs
    Nowy 2018
    Brother DCP-T310W, DCP-T510W, DCP-T710W
    HP Ink Tank
  • #5 17327602
    sebas8503
    Help: 7
    Rate: 12
    I will step on the topic.
    I am faced with a similar choice.
    What mate did you choose?
    I was thinking about three models:
    - CANON PIXMA G3400
    -Brother DCP-T500W
    -Epson L365
    I am most inclined to the Canon.
    As a result of searching the forum, a model was found:
    BROTHER DCP- J105
    Which of these printers do you recommend (here a question for colleagues more knowledgeable in the subject)?
    Or maybe some other sensible, economical model in the budget up to PLN 500-600?
    Yes, I know that inks are hard to recommend (I still use the armored hp 1300n myself), but
    I am forced to buy a color printer with wifi and a scanner.
  • #6 17327914
    dr.master
    Help: 518
    Rate: 927
    I still recommend something from Brother's stable - very cheap inks.
  • #7 17328081
    sebas8503
    Help: 7
    Rate: 12
    a question for a colleague, Dr.master:
    quotation "If a colleague appreciates cheap operation, then only Brother.
    We dilute the bottled carcasses with the draining agent. | "
    I am leaning towards a continuous CISS device, what proportion of the cleaner per ink container?
    What company do you recommend head cleaning fluid, or maybe it's not that important?
  • #8 17328287
    dr.master
    Help: 518
    Rate: 927
    Brother T300 / 500/700 have containers for self-filling ex officio - no additional costs.
    You add 2ml of head cleaning fluid to the entire container - the cheapest one from Allegro is enough.
  • #9 17427707
    paul0
    Help: 6
    Rate: 68
    Give up Epson.
    The new firmware blocks replacements, and the service, parts and consumables have prices out of space.
    This company's printers are extremely fragile and quite emergency.
    Parts are expensive often ... more expensive than an entire printer!
  • #10 17444896
    nakskovnakskov
    Rate: 33
    Brother 625DW 725DW 825DW 925DW 6510DW 6710DW Durable Models Only
  • #11 17490841
    bodzio.c
    Rate: 20
    Thanks to everyone for your help. For economic reasons and brand loyalty, I chose the BROTHER DCP-J105. There is no duplex but it meets my expectations and cheap ink replacements ....
The discussion revolves around selecting an inkjet multifunction device with Wi-Fi and duplex capabilities, following the failure of a Brother DCP-145C. Users recommend staying with Brother due to its cost-effective ink solutions, highlighting models such as the Brother DCP-T310W, DCP-T510W, DCP-T700W, and DCP-J105. Other brands mentioned include Canon and Epson, with Canon's PIXMA G3400 and Epson L365 being considered. Concerns about Epson's reliability and high maintenance costs are noted. Ultimately, the author decided on the Brother DCP-J105 for its economical ink replacements, despite it lacking duplex functionality.
