SMS Text Issue: Unable to Send 5-Digit Top-Up SMS on LG K8 for Chomikuj GB Increase
11961 14
Why can’t I send a 5-digit SMS from my LG K8 to top up GB, even though normal SMS messages work?
You most likely cannot send the 5-digit SMS because your number has a block on premium SMS services, not because of the LG K8 itself [#16256327] If you are in Play, you can disable it in Play24: use https://24.play.pl/Play24/OtherServices and look under Packages and Services → Additional services for locks on premium SMS services or premium service price thresholds [#16256347] [#16258138] [#16258923] The service is not free, and after you send the SMS it is a good idea to turn the lock back on so you do not accidentally receive paid subscription SMS [#16256383] If you still do not see the option in your account, call the operator support line [#16260149]
  • #1 16256325
    Problematyk01
    Help: 11
    Rate: 50
    Either the lack of funds on the account or the blocking of premium operator services.
  • #3 16256329
    Problematyk01
    Help: 11
    Rate: 50
    It depends what network. If Play, you can do it via the play24 phone apps.
  • #5 16256361
    janek1815
    Help: 372
    Rate: 1062
    It's not free. I do not know what kind of locks you have, but if you do it once, put it back once you send it. This will prevent you sometimes if you start getting some paid SMS in the subscription.
  • #7 16257636
  • #8 16257926
    janek1815
    Help: 372
    Rate: 1062
    I do it using Play24 via a web browser.
  • #9 16257982
  • Locating the data transmission package in Play24
    #11 16258221
  • #12 16258855
    janek1815
    Help: 372
    Rate: 1062
    None of the above search is to be a premium SMS or something like that. Unless I have other menus on the phone for the company.
  • #13 16258923
    krzysztofh
    Help: 101
    Rate: 937
    You select the packages and services tab. Here you have three tabs Packages, offer change, additional services. In the last tab you have such items as: locks, locks of premium types of services, locks of premium service thresholds, blocking the price of premium services.
  • #14 16259504
    gacu007
    Help: 11
    Rate: 45
    Yes you should have.
    SMS Text Issue: Unable to Send 5-Digit Top-Up SMS on LG K8 for Chomikuj GB Increase SMS Text Issue: Unable to Send 5-Digit Top-Up SMS on LG K8 for Chomikuj GB Increase
  • #15 16260149
The discussion revolves around an issue with sending a 5-digit top-up SMS for data increase on the LG K8 device for the Chomikuj service. The user encounters a red exclamation mark and a "redo" message when attempting to send the SMS, despite having sufficient funds. Responses suggest that the problem may be related to premium SMS service blocks or network-specific settings. Users recommend checking the Play24 app for service management and disabling any locks on premium SMS. The user also seeks clarification on navigating the Play24 interface to find the relevant settings for premium SMS services.
