Virgin Mobile Lock: Deactivate Premium SMS 7XXX, Use *222 or STOP & 252 Code for PLAY Network
pankracy3 16614 3
  • #1 16799127
    pankracy3
    If you do not manage to call the Virgin Mobile consultant at * 222, and you want to block the inconvenient Premium SMS from paid numbers starting with 7XXX
    you can try to put a lock on your phone yourself. Because Virgin connects the business to the PLAY network, the deactivation code is the same as in PLAY.
    In the SMS, enter STOP and we send to the number 252 . After a while we get a message from the number 6000 "Lock activation has been requested"
    Remember that if you send any SMS to a special type of crossword solution, you block the lock from the machine.
    In the case of a subscription, unwanted SMS can make big bills.
  • #2 16799832
    failedmission
    Rate: 27
    Do you know why they joined? I just moved 4 numbers to them
  • #3 16799884
    viwaldi1
    Help: 49
    Rate: 60
    They did not "merge" and "connect business" :)
    Virgin is a virtual operator operating on the Play infrastructure.
  • #4 16799973
    luki776
    For some time I had a problem sending SMS in Virgin, no SMS center from Virgin to +48 790 998 6222 (yes, 10 digits) according to what they write in the Wiki and this issue does not work for me sending SMS only works receive. After entering the number from Play everything works (+48790998250).
