Jaguar X-Type 2.0d - diagram needed, Burns the stop pedal sensor fuse
Asdzronk 5985 2
  • Clarifying intermittent brake sensor fuse failure while driving
    #1 16258942
    Asdzronk
    Rate: 50
    jaguar X-Type 2.0d burns the fuse from the stop pedal position (7.5A).
    After starting the car and pressing the stop, everything is OK. The fuse only blows when you press the brake pedal while driving.
    After disconnecting the brake pedal position sensor (the upper one - probably from the cruise control), I blown the 15A fuse from the ignition while driving, the car lost its currents and the engine immediately went out.
    I can't find the schematic ele anywhere. for this car. I have a diagram for a Mondeo 2.0 130km but I don't know if it will be the same - the fuses are definitely different.
    Maybe someone toss the ele diagram. for this car?
  • #2 16258974
    CameR
    Moderator of Vehicle Security
    Help: 1141
    Rate: 3274
    Jaguar X-Type
    Electrical Guide 2.0 , 2.5 , 3.0
    Eng. 160stron
    • Jaguar X-Type Electrical Guide 2.0 2.5 3.0.pdf (5.44 MB) You must be logged in to download this attachment.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 16394077
    Asdzronk
    Rate: 50
    thank you for the schematic :) a messy bunch in several places. probably rodents under the hood.
