Peugeot 307 SW - Seat Heating Not Working: Relay & Fuses Checked, Troubleshooting Ideas
trebor1 16191 7
  • #1 16258971
    trebor1
    Rate: 16
    I have a problem with the chairs, namely the heating in both chairs has stopped working. I checked the relay (works), fuses (all). I lost my inspiration, where should I look?
  • #2 16259114
    MarcinS70R
    Help: 52
    Rate: 290
    Check maybe the cubes under the chair do not connect and the multimeter in hand and measure the resistance of the mats.
  • #3 16259522
    trebor1
    Rate: 16
    I understand cubes to check (I did not think about them), but when it comes to mats then two chairs would not fall at the same time.
  • #4 16259533
    andrzej20001
    Help: 1578
    Rate: 6669
    And the mat power supply is on it?
  • #5 16259879
    trebor1
    Rate: 16
    The power supply is on the relay and as on the switch.
  • #6 16261556
    trebor1
    Rate: 16
    The cubes are checked, they are all connected, but I have a question I found some modules under the seats, what are they for?
  • #7 16264550
    trebor1
    Rate: 16
    I checked the mats and they are fine. And the armchairs don't heat up so much, I will check the plugs yet.
    Added after 5 [hours] 12 [minutes]:
    Once again I checked the relay, mats, voltage, everything is ok. And I have a question what controls the heating power of seats? Because there is no such function on switches.
  • #8 16931870
    Clbw
    Rate: 20
    Topic a year ago, but for me the situation looks similar and there are no ideas what to do next. Did you fix the seat heating, buddy?
The discussion revolves around a Peugeot 307 SW where the seat heating has ceased functioning. The user has already checked the relay and fuses, confirming they are operational. Suggestions include inspecting the connections (cubes) under the seats and measuring the resistance of the heating mats. The user notes that both seats are affected, which raises questions about the power supply and control mechanisms for the heating. Despite checking the mats and voltage, the heating issue persists, leading to inquiries about the modules found under the seats and the absence of a heating power control function on the switches. A follow-up from another user indicates a similar problem, seeking resolution.
