Canon MG2950: How to Enter Service Mode, Reset Waste Ink Error & Resolve Kod 5B00 Issue
testujemy.soki 9699 3
  • #1 16947356
    testujemy.soki
    I am looking for a way to reset the waste ink error on the canon MG2950.
    I did not find in the depths of the Internet a description of how to enter the service mode and information about which srevice tool to reset the error.
    I am not successful at random and the methods from previous models do not work.
    Help.
  • Service mode reset procedure for waste ink counter
    #3 20421965
    Fiolek77
    Rate: 22
    It gives the procedure to Reset Pampers:
    Download ServiceTool V3400
    The printer needs to be put into service mode.
    1. With the printer turned off, hold STOP, turn on the printer, release STOP while holding the POWER button and now, while holding the power button, press STOP 5 times, then release the POWER button.
    You are entering ServiceTool V3400
    2. You press EEPROM, a window with values will pop up (i.e. it connects to the printer) as there is error 006, i.e. the printer has not been entered into service mode, something wrong done in 1 point
    You close the window with the values.
    3. Press SET at - Counter Value(%) (0)
    You close everything and turn off the printer after turning it on it should work.
    It also gives a different version of the Program as if that one didn't work
    Video: https://www.youtube.com/watch?v=KMCYPV9lXuY
    • ServiceTool_V3400.exe (434 KB) You must be logged in to download this attachment.
  • #4 21229003
    Shouer21
    This is a waste of time, it doesn't work with MG 2950.
