[Solved] Delonghi ecam 23.110b - Replacement of the milk frothing nozzle on the autocappu
6711 6
  • #1 16942899
  • #3 16943581
  • #4 16943937
  • #5 17048040
    misialsa
    Hello. Did you replace this foaming tip?
  • #6 17049606
    nioop
    Home appliances specialist
    Help: 503
    Rate: 3319
    janek59h wrote:
    By the way, I must admit that I regret buying a DeLonghi machine. It works fine, but almost nothing on the internet about replacing parts, cleaning parts (disassembly and assembly). I suspect that this is the company's "job", because there is a lot about these things in Krups, Siemens and Saeco machines on the Internet.
    It's strange, because once - you should be glad that the equipment is so low-failure that few people publish its demolition.
    Two - to regret that you bought a device for which there are no YouTube videos so that you can spin it up and turn it every day without a reason - it's a bit strange approach. Apart from the fact whether it is a TV or a coffee machine.
    Please do not pick me up wrong, but I imagined a customer who comes to the store, e.g. a neonet and asks the seller if there are a lot of movies on the Internet for this washing machine, how to unscrew it and screw it on because that determines my purchase.
    In case of problems with technical bulletins, please write to priv. Will be happy to provide something if needed ..
    To the subject - the tube would have to be threaded after disassembly and the tip from the jury should be used.
    Kawa i Naprawa - Serwis AGD
  • #7 17314824
✨ The discussion revolves around the replacement of the milk frothing nozzle on the DeLonghi ECAM 22.110B coffee machine. Users express skepticism about the feasibility of replacing the frothing nozzle with a compatible part from a Saeco auto-cappuccinatore. One participant notes that the diameter of the frother hole matches the metal tube of the DeLonghi model, suggesting that it may be possible to adapt the nozzle with care to avoid damaging the frother. However, there are concerns regarding the lack of online resources for maintenance and part replacement for DeLonghi machines compared to other brands like Krups, Siemens, and Saeco. The conversation also touches on the warranty implications of making modifications.
