VCDS EGR Disable Guide for BLS with DPF (2010): Step-by-Step Process & Login Details
Volda 22488 3
  • #1 16262228
    Volda
    Wtam
    Anyone know how to disable egr in bls with dpf year 2010?
    I found the login, the program accepts but I don't know if it changes anything.
    http://loginvcdsvagcom.blog.pl/files/2017/02/image.jpeg
  • #2 16266122
    biba24
    Help: 19
    Rate: 181
    Many know how to do it. VCDS will not turn it off, map editing needed.
  • #3 16266665
    ABRAM_TJE
    Rate: 18
    Exactly as a colleague wrote above.
    you need to gently lick the map.
    pzdr
    Moderated By CameR:
    Reg. 3.1.11. Do not send messages that add nothing to the discussion.
  • #4 16272244
    marcin_70
    Help: 38
    Rate: 269
    Turning off EGR in a car with a DPF is a shot in the knee ...
