VW Crafter 2009 2.5 TDI CEC Engine: DPF Replacement Using VAG CAN Professional
Pfemek 12666 7
  • #1 16244378
    Pfemek
    Help: 83
    Rate: 338
    Could someone give me how to replace DPF with a new 2.5 TDI CEC engine in Crafter 2009? I have VAG CAN Professional but after connecting to the engine I do not have access to matching channels. Only a long fit is available but I don't have a channel description ...
    Thanks in advance...
  • #3 16245170
    Pfemek
    Help: 83
    Rate: 338
    I've reviewed before. Everything is ok, only regeneration and not replacement. Do you need to regenerate after installing the new filter? I don't know if it will run at all because the filter's full limit values are already reached.
  • #4 16245207
    szymitsu21
    Help: 342
    Rate: 1292
    and I'm sorry ..
    you have to do the exchange but it's also all done.
  • #5 16245227
    Pfemek
    Help: 83
    Rate: 338
    I was browsing but I can't find :| . I have to search again. But if something is waiting for a hint ...
  • #6 16248164
    Pfemek
    Help: 83
    Rate: 338
    Anyone else have any idea? I can't find on rosstech. There are procedures but for other engines ...
  • #7 16248268
    szymitsu21
    Help: 342
    Rate: 1292
    Engine -> adaptations -> channel12 -> new value "0"
    Or VAS and do it yourself, come to Krakow and we will zero :)
  • #8 18155049
    bearbig
    Rate: 28
    I heat the topic, what is Security Access for this engine, for c ... None come ... I want to reset the dpf after replacement .. Anyone know? :-)
✨ The discussion revolves around the replacement of the Diesel Particulate Filter (DPF) in a 2009 VW Crafter equipped with a 2.5 TDI CEC engine. The user seeks guidance on using VAG CAN Professional for this process, specifically regarding the lack of access to matching channels for DPF replacement. Responses suggest that after installing a new filter, a regeneration may be necessary, although the user is uncertain if the engine will operate due to the filter's full limit values being reached. Suggestions include accessing adaptation channels to reset values and inquiries about security access codes for the engine to facilitate DPF reset post-replacement.
