Vw Golf IV 2000 1.9 TDI 110KM: EGR Blinding Guide - Unclipping Control Vacuum & More Tips
tirross 5388 3
  • #1 16741274
    tirross
    Rate: 9
    How to blind EGR? It is enough to unclip and plug the control vacuum, or do you need more mechanical?
  • #2 16741480
    sulof1601
    Help: 94
    Rate: 281
    Hello. And why do you want to blind it? What you describe is almost enough, but it was still necessary to plug the metal pipe going from the exhaust manifold to the EGR.
  • #3 16742918
    tirross
    Rate: 9
    Heard the car is getting livelier.
  • #4 16743088
    CezaryL
    Help: 9
    Rate: 21
    A few years ago I blinded the Egr Valve. It was true that it was the Alfa Romeo 146, but it will be similar in the Golf. At the inlet to the Egr, between the flanges I put a blanking plug made of about 0.5 mm thin sheet metal. Since then I have had no more problems with locked Egrs, the driver did not report any errors either.
