Audi A4 B7 - 8E0920931Q Clocks Swap & Key Matching Process - Transponders & VDC 5.29 Use
koloboro 6426 2
  • #1 16441707
    koloboro
    Help: 8
    Rate: 30
    I'm in the process of swapping colored clocks into my fury.
    I have purchased 8e0920931q clocks.
    Immediately I say that the immo will be off because the versions do not match.
    Gentlemen, please help me put out the inscription safe on the meter. I understand it's a matter of matching the keys. The question is whether you need new transponders? What is the procedure of adding new keys?
    I have VDC 5.29. I made copies of eprom.
  • #2 16441811
    adam7009
    Help: 656
    Rate: 1635
    you will not do without the appropriate equipment, vcds or VDC you will not do anything, I can help but I have to have a meter at home, unfortunately, if I have something, I can help.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #3 16450710
    koloboro
    Help: 8
    Rate: 30
    And here I will not agree with my friend. I read, searched, tested and the thing is that the meter chula like a tralala.
    And I made it VDC.
    First, a primo copy of eprom on three different carriers. Believe that it will come in handy when you do it for the first time. In the event of a def error or other such, you will not put the counter on its feet without expensive equipment.
    1. You had to buy new pre-coded transponders for Audi: Transponder Megamos Crypto - Audi CAN ? JMA: TP25 ? Silca: A2
    2. Make a counter for virgin, status immo - 1 that is clean as from the store
    3. VDC has the Add Key function and I used it - twice because I made two keys :)
    4. Setting up the waveform
    5. Typing Vin
    6. Coding the meter for your equipment
    7. Learning airbag to new clocks
    And below is a photo from the first test drive.
    VDC needs to be sure.
