DIY Roccat Syva headphone repair: Learn how to fix headphone issues
mastersq10 11019 14
Can a Roccat Syva headset with one dead earpiece be repaired yourself, and how do you find where it broke?
Yes — these headphones can usually be repaired if you locate the broken section, most often at the 3.5 mm jack or in the handset cable [#16266241] Play music and move the cable at the plug and at the damaged earpiece; if sound comes and goes there, that is likely the break point [#16267725][#16270748] If the jack is bad, the simplest fix is to cut it off and solder on a new 3.5 mm TRS plug, such as a Neutrik NYS-231BG [#16266267][#16266543] If the fault is in the earpiece, try opening it; the casing is often glued or ultrasonically welded, so heating the plastic and carefully separating it can help [#16266241][#16266442] Then shorten the damaged wire by a few centimeters and solder it back together [#16266442][#16270957] If moving the cable anywhere does not change anything, the break may be inside the earpiece/cable and the repair becomes harder [#16270748][#16270927]
  • #1 16266143
    mastersq10
    Rate: 24
    I have a problem with my Roccat Syva headphones. The problem is that one handset suddenly stopped working. My question is this: can you fix it yourself, or is it over?
    Thank you in advance for your response.
    byku022
    Help: 6
    Rate: 20
    Hey
    Has it stopped working by itself? or did you pull on the cable when pulling it, or jerk on the handset, it could also cause it to stop working or how you used them outside in such weather, in what circumstances did it happen?
    Locate cable breaks and resolder shortened wires
    #3 16266241
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    Usually the headphones are broken at the jack or the handset.
    It would be necessary to locate the place where the break occurred, e.g. by moving the wires while playing music, if we locate the place whether it is at the headphone or m.Jacku then the decision whether it is possible to open the handset is usually ultrasonic welded or glued shorten the wire a little and solder. As for M. Jacek, it's a little harder to try to take off
    plug cover and also shorten a piece of wire and solder the wire.
    byku022
    Help: 6
    Rate: 20
    With jack molding, it can come out a linden, it is better to buy if you need the 3.5 jack plug and solder.
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    Replacing m. Jacek with a new one is the simplest thing, but keeping the original one is a bigger challenge.
    I personally heat the plastic casing, then with a very thin screwdriver I separate the casing from the metal part and then just soldering and folding back.
    byku022
    Help: 6
    Rate: 20
    No yes, no matter how you do it, it works, although I personally have to, because I know that I will often use the jack, I buy the plug, solders and finally gives a shrink tube.
  • #7 16266504
    mastersq10
    Rate: 24
    They last worked this morning, the next use and notice of the fault occurred in the afternoon. This cable is flat, I don't know if it could be broken so easily. As for exchanging the jack, how much can such a jack cost?
  • #8 16266543
    byku022
    Help: 6
    Rate: 20
    3.5 jack plug, for example, Neutrik PLN 6 audio store, etc.
    Neutrik NYS-231BG 3.5mm TRS jack plug
  • #9 16267711
    mastersq10
    Rate: 24
    I will look for him and we will see.
  • #10 16267725
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    One more question is there a 100% break at the M.Jack plug? Does the sound appear in both headphones when the cord is moved around the plug?
  • #11 16269680
    mastersq10
    Rate: 24
    I moved the cable in every direction and did not notice any changes. That the Jack plug is not to blame.
  • #12 16270748
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    Buddy, also move the cord at the damaged earphone and see if there is a sound if it appears, it means that the damaged cord is in this place.
  • #13 16270927
    mastersq10
    Rate: 24
    Lord buddy, I moved and still nothing. So the earpiece should be the same? It can be repaired somehow. I will add that the warranty has already expired after I lost my receipt.
  • #14 16270957
    Sławek 61
    Level 19  
    Help: 29
    Rate: 140
    It is difficult to advise something if you do not see it, I personally would try to get to the earphone itself to check if it is good if good, I would shorten a few centimeters of the cable and solder to it if it still does not work, Jack also shortens a few centimeters of the cable and replacement of the plug .
  • #15 16271350
    mastersq10
    Rate: 24
    I close, these headphones do not work and period.
The discussion revolves around troubleshooting and repairing Roccat Syva headphones, specifically addressing an issue where one earpiece has stopped functioning. Participants suggest that the problem may stem from a break in the cable or the jack. Techniques for diagnosing the issue include moving the wires while playing music to identify the fault location. If the break is found, users recommend opening the earpiece, shortening the wire, and soldering it back together. For jack issues, replacing the 3.5mm jack plug is advised, with specific recommendations for brands like Neutrik. The conversation highlights the challenges of repairing the headphones, especially after the warranty has expired.
