Hyperx Cloud II Headphone Repair: 5 Cables, 3.5mm 4-Pin Jack, Soldering Guide & Tips
motorados 13068 1
  • #1 16880864
    motorados
    Hyperx Cloud II Headphone Repair: 5 Cables, 3.5mm 4-Pin Jack, Soldering Guide & Tips Hyperx Cloud II Headphone Repair: 5 Cables, 3.5mm 4-Pin Jack, Soldering Guide & Tips
    Tries to fix Hyperx cloud II headphones (7.1)
    There are 4 cables on all YouTube guides showing how to solder these cables to the 4 pin plug. I have 5 (red, copper, green, blue, red-green). Could someone advise me how to combine it so that it would have arms and legs? Photos in attachments [/ img]
  • #2 16882150
    bogi
    Help: 103
    Rate: 245
    According to the photo in black insulation, our microphone is removed. One ground, the second signal with power, but to make it more difficult, you have to find which is which.
    In the white, the right and left headphones and a common ground. You need to check which one is common to both headphones.
    You have to connect the selected ground from the headphones and the ground from the microphone together.
