Can I retrofit a multifunction steering wheel to a 2011 Passat B7 by swapping the wheel and coding it, or do I need a different steering column module/wiring, and what coding is required?
You can only retrofit the multifunction steering wheel if your steering column control module already supports it; if VCDS rejects the coding with “Request out of range,” the current module does not support multifunction buttons and must be replaced [#16268279][#16282921] For the Passat B7, check the module number on the sticker rather than only in VCDS, because the diagnostic screen can show a different combined-switch number; compatible examples mentioned in the thread were 3C0-953-549xx / 3C9...BG, and later 5K0-953-569 variants such as BA and H were reported working after replacement [#18083960][#18084002][#18197084][#18226457] The buttons are connected to the steering column module, so it is not just a wheel swap; you may also need the correct clock spring/ribbon cable and associated wiring [#16283531] One coding example given for a car with cruise control was 19 9A 25 00 00 [#16283531]
I have Passat B7 from 2011, I have cruise control and touch-sensitive radio, I would like to add multifunctional to it? What coding in the driver do I need to carry out? And how to check whether it is enough to change the steering wheel and encode, or is it necessary to replace the module / add a beam? Cushion fits from one steering wheel to another?
the numbers for which it is shown which one supports multifunctional functions are: 3C0-953-549 that is, different from mine.
My module after entering the steering wheel [16]> Codding and selecting multifunctional functions: "Coding Reject, Error 31 Request out of range" so I presume that it does not support multifinks, but if so why is it that VCDS long coding helper is able to mark Multi support? ...
I understand that in order to get a mulit in the Passat B7 I still need to buy a beam, but what are the parts of the beam and the keypad module? Pass from B6?
The number given by you is the number of combined switches. As you enter the steering module you have two numbers, one for the column driver, one for the switch. But it does not change the fact that as the module rejects coding, it does not really support the MF's steering wheel.
Passat B7 multifunction steering wheel module location and absence
so entering the number that gives out switches combined, but as I understand correctly, I have to enter in [Steering Wheel] 17
And there I have only one number. Below screen: Is it possible that there is no module at all in B7 if there is no Multi steering wheel? I will add that I have removed the covers of the casing behind the levers and there is no module, no module ... Where should he be in the Passat B7?
The multifunction will handle 3c9 ... BG for sure. According to the diagram, connect buttons with the module, coding - for variant, with cruise control will be 19 9A 25 00 00 and it will wiggle.
The number you enter is ETKA according to the complex switch. For me, two values are displayed on the diagnoscope, a combination switch and a steering wheel controller. In newer Vagas, the steering control is integrated with the tape and has the numbers 5K0953569 with letters. Unfortunately, ETKA does not give the number of this module for many, only read from the car because they probably pushed what they had.
By the way, now I'm fighting this in Yeti and I can not encode. I have module 5K0953569AF. It does not accept coding but it is supposed to be a highline - I do not have 100% confirmation of this.
Ok, that is, according to you, the tape is a tape and talk VCDS shows well, and this is my driver 3C9953501BP I'm sure it will handle Mulitunctions. But he does not accept coding and he rejects; /; / Whether the reason for rejecting coding can be an error with steering Assist [44] ?
I have two such errors and non-working support:
44 Stering Assist 2 Faults Found
00003 Control Module 012-electrical Fault in Circuit - MIL ON
02546 - Steering Limit Stop 005- No or Incorrect Basic Setting / Adaptation
One in my opinion, where the break in the beam going to the support When the mangle is all ok, there are three plugs all plugged in and two large wires have 12+ and Mase. the rest of the wires, as far as you can see, is not torn (but I do not know where it goes to check the continuity with the multimeter). Second this adaptation, previously made the mapping of the G85 mole sensor has passed, but this adaptation; http://wiki.ross-tech.com/wiki/index.php/02546
Perform Steering Limit Stop Adaptation Make sure the Ignition is ON and the Engine is Running. Center Steering Wheel (? 10 °) and hold it centered for about 5 Seconds. Turn Steering Wheel to the Left and hold there for about 10 Seconds. Turn Steering Wheel completely to the right. 10 Seconds. Center Steering Wheel (? 10 °). Switch Engine and Ignition OFF. Switch Ignition ON. Wait about 5 Seconds. Steering Assist Warning Lamp should turn OFF (If it does not, perform a short Test Drive).
He does not quench the error anymore.
mistakes after removal always return after a while from firing the car. Red steering wheel at TAcho.
This can interfere with coding kiero? How do you fix these errors?
hello, I would like to connect to this thread, I have a similar problem with connecting multifunction, I have a cc 2011 passatio and actually I do not know what's going on because the steering wheel with B7 after connecting, does not work even the horn, but does not show any error, but rejects coding, do I have to buy a new module, or something can be carved with what is.
thanks for answer my question if this steering wheel will work with this module ... do I have to buy the module? I do not understand the operation of certain functions in VCDS, I set the parking lights on DRL and adopted the coding correctly, but the lights do not work as DRL the same with the coming home function works, but liaving home does not work, I also have no option to turn off the cold bulb control, the previous B6 2007 was not there.
In newer cars, it will not turn off the cold diagnosis of the front lamps anymore. Enter the number of the module under the steering wheel (3C0-953-549xx)
I will check tomorrow because the steering wheels should be removed, I have to remove the pillow, and it's aku. need to unhook, etc. ... and from another barrel, sometimes I am asking error P0403 I know that this is a problem with the EGR electrician, but when I look in VCDS it works like egr: 40%, 70% unless something is cut, or the coil is hard and raining, the burn is doing normally, but it shows a parallel message that the start / stop system is not working, is this EGR the cause? greetings
I found the code but I'm not sure if it's the one on the photo, in addition I will say that the plug has 6 pins, two upper ones from the pillow and the bottom four correspond to the wires in the socket coming out of the new steering wheel, that is the chance to cooperate.
Added after 24 [minutes]:
Well, I can see that it probably will not work, it must be 5K0-953-569-H, -BA, -AL, -AP, - T
hello again, I was able to buy the 5K0-953-569 BA module - I installed - of course the power steering, tires and traction control lights are burning, what coding should be for my car, I marked multifunctions in coding and coding was adopted, but nothing was accepted changed, I tried to do the steering wheel adaptation a few times, but it does not squeak at the extreme positions of the steering wheel at all, will anyone tell me what I am doing wrong, because by installing the old module everything returns to normal and the adaptation of the support comes out the first time, of course the tire indicator goes out even in reverse .
hello EGR problem solved, the wire from which the return spring was made came out so much that it blocked the rotation of the crescent was shortened by 2 mm, unfortunately it was not possible without dismantling the entire radiator, because some engineer insisted that the screws fixing the adjuster itself were from sides of the engine compartment. As for the problems with the multifunction, the module I bought earlier had a damaged circuit board - I returned, a new one with the letter H works: the steering wheel is illuminated, the shifters change gears, the horn of the trumpet, the cruise control works, all the lights went out after adaptation, unfortunately no buttons work neither from the on-board computer nor from the radio, I will add that the computer is easily operated by the switches in the right wiper handle which I turned off from VCDS, there was such an option, but this did not change anything on the steering wheel, of course the above control of the computer in the handle does not work. Please help I missed something that needs to be done for the steering wheel buttons to be active.
Added after 1 [hours] 34 [minutes]:
I also noticed that after removing the key after a few seconds (not every time) blinks and signals (several times) with a sound similar to the unfastened belts, yellow steering wheel indicator, what is this about? unless the electronic steering lock does not work.
The discussion revolves around retrofitting a multifunctional steering wheel in a 2011 Passat B7, which currently has cruise control and a touch-sensitive radio. The user seeks guidance on necessary coding, module compatibility, and whether additional components like a beam or module replacement are required. Responses indicate that the existing steering wheel control module (3C9953501BP) may not support multifunctional features, as coding attempts result in errors. Participants suggest that a compatible module (3C0-953-549) is needed, and some mention the importance of checking wiring and connections. Issues with coding and functionality of the steering wheel buttons are also highlighted, with suggestions to verify module numbers and connections to resolve errors. AI summary based on the discussion. May contain errors.
