VW Passat B6 2007: Multifunction Steering Wheel Coding with Module, VAG Lite, & VCDS
ptakuwzl 12291 3
  • #1 17215067
    ptakuwzl
    Rate: 17
    I warmly welcome,
    Could someone tell me how to start programming the multifunction steering wheel in Passat B6 2007? I have a module, a steering wheel, VAG Lite software and VCDS. Someone might say how to do it. I am a complete layman in these matters :D best regards
  • #2 17216174
    Kuba6625
    Vcds group comfort module. And there you add new coding
  • #3 17216744
    ptakuwzl
    Rate: 17
    It doesn't tell me much. Where to get the codes I say I'm a complete layman and I don't know how to go about it. OBD cable I have forgot to add
  • #4 17220606
    ptakuwzl
    Rate: 17
    I managed without programming. The problem arose as follows. Yellow power steering indicator, ESP off and cruise control reset. What could this cause?
