The samsung phone is given a guarantee of exchange for a new one?
fenri95 9450 15
Should I request the replacement Samsung phone from the manufacturer or from the seller listed on my Allegro purchase document?
Take Samsung’s service authorization to the seller or distributor named on the original receipt or invoice and request the phone’s replacement there. The manufacturer is the guarantor, but this document authorizes the dealer or distributor to exchange the device, with Samsung settling the transaction separately with them [#16269880] The seller should provide a new or equivalent model as specified in the authorization, rather than necessarily having Samsung send it directly [#16269699] If the purchase document identifies an operator, contact that operator; if it identifies a commission shop, pursue the claim against that shop [#16271123] Keep and provide the original proof of purchase, since it documents the device’s warranty status [#16271283]
  • #1 16269673
    fenri95
    Rate: 74
    I received the following response from Samsung's Samsung phone: "In response to a complaint made by Samsung Electronics Polska, we provide the AUTHORIZATION to replace the device with a new copy or equivalent of a new offer or another settlement method agreed with the seller." The phone was bought some time ago on the Allegro, how to solve this problem correctly, should I be reminded of an allegrowicza new phone or producer?
  • #2 16269699
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    The service should give a new phone the same or a new model equivalent to the previous one and not the seller because the producer is the guarantor.
  • #3 16269702
    fenri95
    Rate: 74
    I got a broken phone with such information as I should now do about it?
  • #4 16269711
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    In what service was the telephone?
  • #5 16269718
  • #6 16269880
    OlekMTG
    Help: 219
    Rate: 194
    The manufacturer is a guarantor, but he does not have to give you a new device - as he says that there is nothing you do him ... In this case, the manufacturer suggests another solution acceptable by law.
    The above document is a kind of expert opinion, authorizing the dealer / distributor to replace the equipment, at a later stage Samsung will settle this seller / distributor in the form of a credit note (however, this is not important for the customer). At the moment, you should go to the entity that appears on the purchase document (receipt / invoice) as a seller and request the replacement of the device based on a document issued by the service.
  • #7 16269898
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Something has changed in the rules? Whenever the service stated that the equipment is not suitable for repair and for replacement, they send a new phone every time and no one sent to the seller.
  • #8 16270869
    tonk
    GSM specialist
    Help: 137
    Rate: 57
    You can send back, olegmtg is right, I've had this case twice
  • Service replacements may be refurbished, unlike operator exchanges
    #9 16271057
    OlekMTG
    Help: 219
    Rate: 194
    For most manufacturers it is cheaper to replace the device at the service level, they simply exchange the phone itself (usually on the so-called refurbished). The exchange with the operator means that the customer will get a whole new box with accessories and the manufacturer will have to pay the entire amount of the seller. Sometimes, however, for a large company it is more important for the budget of which the department will go - service, marketing or sales. In principle, for the client, such a method is definitely more beneficial if the phone comes from a legal source and local distribution.
  • #10 16271098
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    The customer takes a phone call from the operator, sells it to the commission and this one in turn puts on the Allegro and is bought there by the subject's author. Who in this situation is going to give him a new phone?
  • #11 16271123
    OlekMTG
    Help: 219
    Rate: 194
    In this case, the operator, unless the commission has cheated the customer and sold the device as 'new' (although de facto in the light of the law is already used device), then the customer has the right to pursue their claims in court from the commission.
  • #12 16271124
    tonk
    GSM specialist
    Help: 137
    Rate: 57
    If he has an operator's fv receipt, he is the operator.
  • #13 16271179
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    OlekMTG wrote:
    unless the commission has cheated the client and sold the device as 'new' (although in fact it is already a used device in law)
    What does the warranty change in this case whether new or used? Nothing changes.
    You buy a commission as a used one because there is a way to pay zero. :D
  • #14 16271245
    jubi20
    Help: 90
    Rate: 10
    Change because if you send a phone to the guarantor without the original purchase document, the guarantor can treat it as a used device and does not have to repair the warranty :) .
  • #15 16271283
    OlekMTG
    Help: 219
    Rate: 194
    Exactly, the proof of the warranty is the original proof of purchase - when the device was first sold for retail sale.
  • #16 16271408
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    In this situation, of course. I personally buy, resell, but always with this first proof of purchase and I did not even think about doing it differently.
The discussion revolves around a user's inquiry regarding the warranty exchange process for a Samsung phone purchased on Allegro. The user received a response from Samsung indicating authorization for a replacement device. Responses clarify that the manufacturer is the guarantor and should provide a new or equivalent model, not the seller. Users suggest contacting Samsung directly and emphasize the importance of having the original proof of purchase to avoid complications. There are mentions of the process involving refurbished devices and the implications of purchasing from a commission seller. Overall, the consensus is that the user should approach the seller with the warranty documentation for a resolution.
