VW Passat B5 1.9 tdi 110HP - Vibration after pillow replacement
jacekni 8490 6
  • Seeking cause of new idle vibration and gearbox oil suitability
    #1 16270904
    jacekni
    Rate: 8
    A few days ago I had a problem with reverse gear. He just disappeared, so I just drove forward to the nearest workshop and left them the car to be repaired. after about 3 hours I have a phone that the gearbox needs to be changed and that the oil in it was like a medicine. They asked whether to look into the chest or leave it alone, so I leaned so that they would not move and I would come up with something. They also suggested replacing the pillows under the box and the engine, because they noticed some vibrations that I had no idea about before. I agreed because I thought maybe something was vibrating and I got used to it. After about an hour they call that it is backward, but they could not explain what was the reason for his disappearance. They said they were still waiting for pillows and in a few hours it would be ready for pickup. Glad I went for the car after the next phone call and actually the reverse worked, but they refilled my oil not as I thought GR5 75W-90 only (Elf) NFJ 75W-80 . Maybe it doesn't matter, I don't know, but I felt it a lot of steering wheel vibration at idle and strange humming in the cabin while driving (unless the vibrations are transferred to the cabin), which was not before. So I came to them asking why it was so and he tells me that the pillows have to be arranged. I've done about 200km since then and no changes. Maybe you have an idea where these vibrations and this buzzing in the car .... And whether the oil is OK.
    wiesiek3d
    Help: 101
    Rate: 655
    You can still loosen all the pillows and tear the engine, sometimes the tensions will arise and it's ok, but it depends a lot on what they put on the pillows.
  • #4 16273458
    jacekni
    Rate: 8
    Thank you for the hints. Rather, I will visit them and propose an exchange. And the oil question is, is the one I wrote about in the post suitable for the box in the older car, i.e. passat b5, 1.9tdi 110KM?
  • #5 16274274
  • #6 16274339
    jacekni
    Rate: 8
    I know that it is dedicated to Renault, but I have some doubts whether it will fit vw without any side effects, because every company has its own criteria ...
  • #7 16274411
The discussion revolves around a VW Passat B5 1.9 TDI 110HP experiencing vibrations after the replacement of engine and gearbox mounts (pillows). The user initially faced a problem with the reverse gear disappearing, leading to a gearbox inspection where it was noted that the oil was in poor condition. After the replacement of the mounts, vibrations were reported, prompting suggestions to check the quality of the new mounts. Concerns were raised about the compatibility of the oil used, which was originally designed for Renault gearboxes, and whether it would be suitable for the VW Passat without adverse effects. The consensus indicates that while the oil meets certain standards, manufacturer recommendations should be followed for optimal performance.
