[Solved] Passat b6 2.0 tdi pd 140km bkp - Gas addition and subtraction jerking + z
Passssat 12132 7
  • #1 17182588
    Passssat
    When I let go and add gas in every gear, apart from starting, it jerks the car. The jerks are quite strong, especially at high speed. In addition, when I turn the steering wheel to the left, e.g. on a road bend or a sharp turn, when releasing and adding gas, or after changing gear and adding gas, you can hear a grinding noise. You cannot hear anything when you turn the car and add the gas evenly. You hear nothing as you turn right. You can feel a clear slack. I would like to add that 7 thousand km ago I replaced the two-mass complete with a clutch, 20 thousand km ago, two external joints. These symptoms started some 6,000,000 years ago, some 8,000 km ago.
    Checking by suspension mechanics and external and internal joints nothing showed. They think it's alright And they don't know what it might be. They indicate a differential or broken internal joints.
    205 thousand mileage.
    What could it be?
  • #2 17182635
    dabu
    Level 32  
    Help: 190
    Rate: 695
    Recently, I did the same ailment in b6, when releasing or adding the gas, the clutch slipped, which made it feel like a jerk. after replacing it with new ones as the hand took away.
  • #3 17182647
    Passssat
    Could it be because of a poorly fitted clutch? Is the clutch defect? There is still a grinding noise
  • #4 17184039
    dabu
    Level 32  
    Help: 190
    Rate: 695
    If it is self-adjusting then yes.
  • #5 17184872
    pitbul455
    Rate: 23
    Nothing pleasant when someone spends so much money on a set of clutch and then it turns out that something is happening. For me, after replacing the entire clutch with a new one, it was grinding when the clutch was pressed slightly. The box was about to go downstairs to be checked, after 1400 km it passed.
  • #6 17187098
    Passssat
    Thanks gentlemen.
    Only for me it was grinding before the exchange
  • #7 17450889
    Passssat
    The reason is the play in the box. The grinding is also coming from the chest. A chest for regeneration.
  • #8 17450892
    Passssat
    Clear play in the box. The grinding is likely coming from the differential
The discussion revolves around a Volkswagen Passat B6 2.0 TDI PD with a BKP engine experiencing significant jerking during acceleration and a grinding noise when turning left or changing gears. The user has recently replaced the dual-mass flywheel and clutch, as well as the outer joints, but the symptoms persist. Responses suggest potential issues with the clutch installation, play in the gearbox, or problems with the differential. Mechanics have not identified any faults in the suspension or joints, leading to speculation about internal joint failures or differential issues.
