[Solved] Passat B5 1.9 TDI 130km 2003 - Tiptronic Gearbox Compatibility: 5HP-19, EFR Markings, AVF Engine
Maslo1979 14394 12
What tiptronic gearbox designation fits a 2003 Passat B5 1.9 TDI AVF engine, and can a gearbox with different markings be used?
For the AVF 1.9 TDI, the recommended automatic gearbox designation is EYF; EFR is associated with the 2.5 engine with AFB code, so it is not the correct match for your car [#16801616] Other gearboxes may physically be tried, but the manufacturer’s match for AVF is EYF, and used units with the right marking are still a gamble because history and wear are usually unknown [#16802173][#16802343] If you replace the gearbox with another one of the same type, no adaptation is needed; just check/top up the oil level, clear gearbox/engine errors, and verify again after a test drive with VCDS or similar [#16804129] The repair option should also be considered, because in this case the likely cause turned out to be a damaged torque converter, not necessarily the whole gearbox [#16802343][#17223176]
  • #1 16801121
    Maslo1979
    Rate: 21
    Hello. I have a question. I lost the automatic gearbox and I have a question if a different gearbox with different markings will come, it is known that it must be 5HP-19, it is probably from what I remember EFR that the rest of the markings are for me. The engine is marked AVF. Whether or not there is any indication of the crate other than the EFF Thanks in advance for your help.
  • #2 16801616
    masay1
    Help: 40
    Rate: 81
    the gearbox with the designation EFR was associated only with the engine 2.5 with the designation AFB ...
    while the 1.9 AVF engine should have a gearbox marked EYF ...
    of course you can try to "match" the chest with a different designation
    but it will not be in line with what the manufacturer recommends ...
    AVF engine - EYF gearbox ...
  • #3 16802067
    Maslo1979
    Rate: 21
    Oh just like that EYF. So there can be no other designation? Will not walk?
  • #4 16802173
    masay1
    Help: 40
    Rate: 81
    it can't ... that I don't know ...
    I know, however, that it should be with the designation I gave you ...
    manual gearboxes for this engine acc. the manufacturer matches up to nine markings,
    while automatic only one ... and regardless of which car it was installed ...
    it is best to look for a used crate marked: EYF, but only one with a guarantee; it's so hard ...
    and isn't it worth considering the repair of the one you have in the car? ..
  • #5 16802283
    Maslo1979
    Rate: 21
    The cost of the repair scares me. Maybe I will describe what happened, so one day I saw that there was a stain of oil from the box under the car, so the next day I went to the mechanic who changed the oil for me not a month ago because I thought maybe a gasket or something. I drove maybe about 20 km and the box stopped pulling, I called a tow truck on the spot, the mechanic poured 5 liters of oil to see where the oil was leaking from and found that somewhere from the box and that it is probably necessary to disassemble the box because either some sleeve was worn out or zymering. And knowing life while undressing along the way, it will turn out that something else and several thousand will go. It's hard to find chests with my tag. And I don't know what to do anymore.
    masay1
    Help: 40
    Rate: 81
    as for the box with your designation, it's not that hard to find a drug ...
    there are several of them on Allegro itself, and a dozen on Ebay ... but unfortunately they are crates
    from cars with unknown history, and most of them with considerable mileage ... if not all ...
    from the description you gave, 99% of the torque converter on the sliding sleeve of the oil pump is seized up ...
    well-known topic from ZF gearboxes ... if the gearbox was not "tired" with oil deficiency, it can be repaired while maintaining costs
    on a "normal" level ... of course it depends on you which way you go and what your approach to the car is ...
    I would personally go to repair the one I have (if it was in my car) but first you need to diagnose what happened
    and what would be the costs of its possible repair ... but this would have to be seen by someone who knows about it, and it is good if there was still
    a bit honest ... but that's a topic for another conversation ...
    in sum;
    There are many used crates ... but the question is different ... is it worth investing in them, because they are, to put it mildly,
    (of course in most cases) worn out components that are Nothing or Not Worth much ...
    although, of course, not all of them ... just that it is a lottery, and also not very cheap ... so I don't know if it's worth it ...
    when it comes to my opinion, you already know it ... but the choice is yours ...
  • #7 16802359
    Maslo1979
    Rate: 21
    Thank you very much for your help. I have one more question, what do you think about the manual translation?
    masay1
    Help: 40
    Rate: 81
    changing the gearbox from automatic to manual (and vice versa) is neither that easy nor pleasant;
    and thus it is not cheap ... and it comes to who will do it to you and how will it be done ...
    if you do "something", it is best to have a "donor" in its entirety from which you will transfer all of them
    necessary elements to change the drive from automatic to manual ... and there is a bit of it ...
    the word a little ... a bit here Does not fit ... box, flywheel, clutch, driveshafts, bracket,
    pedal set, console, electrical system, gear selector, etc ... and again the topic of the gearbox returns ...
    manual gearbox bought from the so-called "stimulants" is the same unknown as an automatic gearbox ...
    and repairing such a box does not have to mean lower costs ... and again we come to the same point ...
    is it worth?
    The point is for someone who knows it, to check if it is possible to recode them without replacing them with a machine type ...
    for example, some motor controllers can be re-coded relatively easily and safely to different types of drive train
    and some are model-specific ... and buying used drivers is asking for trouble
    (there may be problems with the police and not immediately, but e.g. if someone wants to code, let's say the key in a later
    time in the service) ... if you have all the necessary elements (and from a reliable source), time, place and know how to do it ... you can ...
    but if you have to buy everything separately, and you have to depend on others, I really advise against ...
    see what happened (diagnose) with the box you have, and if the repair turns out to be unprofitable, then only then decide which way to go ...
    because it may turn out (and hopefully it would turn out) that the repair of the one you have is the best / cheapest solution ...
    nice...
  • #9 16802573
    Maslo1979
    Rate: 21
    Thank you very much. You mentioned earlier that you saw crates on the Allegro and EBAYU. You could toss up some classifieds links.
    masay1
    Help: 40
    Rate: 81
    allegro:
    - 7007993494
    - 7013492825
    - 7013493436
    - 7003089785
    - 6931552212
    - 6762983517
    as for Ebay, there are some of them ...
    but I don't know why I can't copy the number. ads ... but that's not a problem ...
    type yourself in the search engine; ebay.de.
    and then on the Ebaya website just enter EYF ...
    the program will do the rest itself ...
    There are no shortage of chests ... but what they are worth is another topic ...
  • #11 16802621
    Maslo1979
    Rate: 21
    OK thank you. You know, I'll find out about these crates just in case. And I'll make a decision. The worst thing is that there are no box specialists in the area. But what I have to advise, I have already put it on olx for a cheaper sale, but whether it will pay off for me - although the willing ones are not very clear. Everyone would like for free.
    Added after 2 [hours] 47 [minutes]:
    Sorry to bother you again, but I have a question, is it possible to replace the boxes with a second machine at home? And do you have to adapt the new chest with a vag or something like that? I am talking about a chest with the same markings. Thank you in advance for your help.
  • #12 16804129
    masay1
    Help: 40
    Rate: 81
    as for the exchange, it is not very complicated, but you need to know how to do it and you must have what ...
    if you haven't done it yet, and you have a garage and let's say at least a "channel" then I'm afraid it's not enough ...
    a few (non-standard) tools are needed to make it relatively comfortable to do, and a tester is also needed;
    e.g. VCDS or other, but with the function of the Measured Value Block ... and needed e.g. to check the oil condition correctly
    gearbox ... it is a so-called gearbox overflow control system Its level ... and with this type of control it is very important
    the oil temperature in the gearbox, and this one should be checked using the aforementioned tester ...
    As for the question about adaptation after exchange, there is no need (nor is it) to adopt ...
    you only need to check the Oil level in the gearbox (possibly top up) and then "erase" the existing errors in the electronics
    e.g. engine, gearbox and check these systems again after the test drive ... if everything is OK, i.e. the gearbox will work correctly and not
    no faults in the electronics will be generated, it would be recommended to replace the filter and gear oil with New ... although the manufacturer does not provide
    oil change is not Reasonable ... I do not know what they are not recommending its replacement ... but I know for sure that it is neither good nor "healthy" for the transmission ...
    if you still have any questions, write to priva ...
    nice...
  • #13 17223176
    Maslo1979
    Rate: 21
    Problem solved damaged converter
The discussion revolves around the compatibility of automatic gearboxes for a 2003 Passat B5 with a 1.9 TDI AVF engine. The original poster inquires about the possibility of using a gearbox with different markings, specifically mentioning the 5HP-19 designation and EFR markings. Responses clarify that the AVF engine is typically paired with the EYF gearbox, and while alternative gearboxes may be attempted, they are not recommended by the manufacturer. The conversation also touches on the challenges of finding a suitable replacement gearbox, the potential for repairing the existing unit, and the complexities involved in converting from automatic to manual transmission. Users share links to available gearboxes on Allegro and eBay, and discuss the necessary tools and procedures for gearbox replacement.
TL;DR: For Passat B5 1.9 TDI AVF, the correct Tiptronic code is EYF; a leak-caused no‑drive is “99%” a torque converter issue—best to “repair the one you have.” [Elektroda, masay1, post #16802343]
Why it matters: This FAQ helps AVF owners decide fast between repair and swap, avoid mismatched 5HP‑19 units, and verify post‑swap checks.
Which Tiptronic gearbox code fits a Passat B5 1.9 TDI AVF?
Use EYF. That is the specified Tiptronic (ZF 5HP‑19 family) code matched to the AVF engine. Mixing codes risks incompatibility and poor shifting. “AVF engine – EYF gearbox.” [Elektroda, masay1, post #16801616]
Is an EFR gearbox compatible with the AVF engine?
No. EFR was paired with the 2.5 TDI AFB engine. Using EFR on AVF deviates from the recommended pairing and can cause functional mismatches. Choose EYF for AVF. [Elektroda, masay1, post #16801616]
Can I install any 5HP‑19 regardless of the code?
Avoid that. For the AVF, the automatic gearbox is specified to a single code, unlike manuals that accept many. Using a different auto code is off‑spec and risky. [Elektroda, masay1, post #16802173]
My Tiptronic lost drive after an oil leak—what’s the likely cause?
A seized torque converter on the oil pump’s sliding sleeve is the prime suspect. The expert pegs it at “99%” in such scenarios. Inspect before buying a used box. [Elektroda, masay1, post #16802343]
Should I repair my gearbox or buy a used EYF?
Repair yours if the box wasn’t run long with low oil. Used units often have unknown histories and high mileage. Expert view: “repair the one you have.” [Elektroda, masay1, post #16802343]
Is a driveway swap feasible for the Tiptronic?
It’s doable but not beginner‑friendly. You need proper support equipment, some non‑standard tools, and a scanner with Measured Value Blocks. A garage with a pit or lift helps. [Elektroda, masay1, post #16804129]
After installing an EYF, do I need coding or adaptation?
No adaptation is required when replacing with the same code. Set fluid level by temperature, clear stored faults, test drive, then replace oil and filter. [Elektroda, masay1, post #16804129]
How do I correctly check and set 5HP‑19 ATF level?
  1. Connect VCDS (or similar) and monitor gearbox oil temperature.
  2. With engine running, use the overflow method at the specified temp.
  3. After setting level, clear errors and road‑test. [Elektroda, masay1, post #16804129]
What tools or software do I need post‑swap?
Use VCDS or an equivalent tool that reads Measured Value Blocks. You need it to confirm oil temperature during level setting and to clear ECU/TCM faults. [Elektroda, masay1, post #16804129]
Is converting from automatic to manual worth it?
Usually no. You need a full donor: box, flywheel, clutch, shafts, pedals, wiring, selector, and coding changes. Buying piecemeal invites issues and costs. [Elektroda, masay1, post #16802555]
Where can I find EYF used gearboxes?
Search marketplaces like Allegro and eBay; use the term “EYF.” Listings exist, but quality varies. Treat them as a gamble without a solid warranty. [Elektroda, masay1, post #16802606]
What was the final fix in the thread case?
The owner confirmed a damaged torque converter. Addressing the converter resolved the loss‑of‑drive problem after the leak. [Elektroda, Maslo1979, post #17223176]
What’s the risk if I drove with low ATF after the leak?
Running low can “tire” the gearbox and expand the repair scope. If the unit wasn’t stressed long, repair remains viable and cost‑effective. [Elektroda, masay1, post #16802343]
