VW PASSAT B6 1.9 TDI: Knocking Sound from Engine When Clutch is Pressed
quba1988 43401 19
What can cause a knocking sound from the engine side when the clutch pedal is pressed, even on a warm VW Passat B6 1.9 TDI?
A knocking sound that appears when the clutch is partly pressed and disappears when it is fully depressed can be caused by the transmission/gearbox rather than the clutch itself [#14468908] In this case, the clutch, pressure plate, thrust bearing, and dual-mass flywheel were replaced, but the knocking remained, and it was eventually found to be the transmission [#14399021] [#14399384] [#14468908] One early suggestion was a broken pressure plate damaging its housing, which was described as a common fault, so the clutch assembly should be checked first [#14290044] Another reply also advised checking the gearbox and engine mounts, but the later update from the owner points to the transmission as the actual source [#14399093] [#14468908]
  • #1 14290033
    quba1988
    Rate: 20
    Hi. Today I started the car and noticed that when pressing the clutch (lightly and all the way down) I can hear a knocking sound from the engine side. I would like to add that on a warmed up car this also happens. The sounds can only be heard outside. It is not any rasp just a characteristic knocking sound. Does anyone know what this could be?
  • #2 14290044
    Pawel wawa
    Help: 1262
    Rate: 4433
    Quickly pull out the box, a broken pressure plate damages its housing. A common fault.
  • #3 14290080
    quba1988
    Rate: 20
    So this is not a typical symptom of a dual mass wheel but a pressure plate?
  • #4 14290088
    Pawel wawa
    Help: 1262
    Rate: 4433
    I have already written to you. A little more and you will see oil under the car. And you'll be looking for the box....
  • #5 14290099
    quba1988
    Rate: 20
    Thanks for the Suggestions. I will go to a mechanic as soon as possible.
  • #6 14399021
    quba1988
    Rate: 20
    Hi. I wanted to get back to the topic because I replaced the pressure plate, the clutch complete, and I can still hear the knocking, except that it stopped when I push the clutch pedal all the way in. Now only the knocking can be heard when I press the clutch halfway. I will also add that it slightly jerks in 1st and 2nd gear at 1500-2000 rpm.
    When pressing the clutch while driving, you can feel the vibration (All this was also before the replacement).
  • #7 14399093
    jack200
    Help: 6
    Rate: 85
    Are you replacing the clutch thrust bearing? Take a look at the cushions under the transmission and engine I had similar symptoms with dead cushions in my fiat.
  • #8 14399384
    quba1988
    Rate: 20
    I replaced the thrust bearing and I can't figure out where the knocking on the half clutch is coming from. Isn't it something with the transmission? I can feel the friction on the clutch pedal, and the knocking can be heard from the engine side, well, and that vibration while driving.
  • #9 14399392
    Altus_140
    Help: 41
    Rate: 42
    Probably cushions to be replaced.
  • #10 14399476
    quba1988
    Rate: 20
    What does knocking at half clutch , at idle have to do with the cushions?
  • #11 14399874
    jack200
    Help: 6
    Rate: 85
    After all, you wrote yourself that in first and second gear it jerks you around.
  • #12 14400083
    quba1988
    Rate: 20
    It jerks when accelerating , and knocks at a standstill at idle with the clutch half depressed. So these could be two different problems.
  • #13 14400323
    wojt3k
    Rate: 101
    And did you replace the dual mass????
  • #14 14400792
    quba1988
    Rate: 20
    wojt3k wrote:
    Are you replacing the dual-capacitor??
    Yes I did.
  • #15 14400958
    marek1772
    Help: 11
    Rate: 118
    Buddy could you zoom in on where the sound arises? From what you say nothing.When does this sound arise,whether when you press the pedal hard or when you press the pedal lightly or no change.What I mean is whether the fluid pressure in the clutch has any effect on it.
  • Clutch-pedal-dependent knocking and drivetrain muffling symptoms
    #16 14401142
    quba1988
    Rate: 20
    marek1772 wrote:
    Kolego could you zoom in on where the sound arises? From what you say nothing is clear.When does this sound arise,whether when you press the pedal hard or when you press the pedal lightly or no change.What I mean is whether the fluid pressure in the clutch has any effect on it.
    The sound can only be heard outside, I can't tell from where it's coming because it's spreading through the engine (I mean knocking).It starts when I press the clutch gently, it stops knocking when I press the pedal all the way in. When I start or reverse by letting go of the clutch the knocking is louder and you can feel a distinct "Muffling" of the car.
  • Check clutch hydraulics before diagnosing crankshaft play
    #17 14401246
    marek1772
    Help: 11
    Rate: 118
    It is unbelievable what you are writing about.Such a symptom MAY be caused by play on the crankshaft shims, but in 1.9tdi I have not yet encountered this.Taking into account the transmission no play will cause a decrease in engine power.I had such a sound in a sprinter which had damaged injectors and dual mass wheel as a result of which the crankshaft in it broke.The symptoms were the same.However, I am in favor of starting with the most trivial causes such as a loose clutch supply line or undercranked clutch pump.For a deeper diagnosis, I recommend removing the plate under the engine and listen to the problem with the help of a second person.
  • #18 14401919
    quba1988
    Rate: 20
    Unfortunately I will have to go to the mechanic again. The situation requires that I have to drive this car abroad therefore every little thing irritates me. Thank you gentlemen for your help
  • Knocking traced to transmission after clutch replacement
    #19 14468908
    quba1988
    Rate: 20
    Hi. I am refreshing the topic because it turned out to be the transmission. I am looking for a new transmission for now but the mechanic suggested to drive around and see if the knocking goes away after some time (after replacing the clutch, dual mass, pressure plate etc . He explained that maybe the synchronizers in the transmission will improve. I don't know but was he right? So far I drive and it is knocking .
  • #20 20108136
    kosmobartek
    After a few years or maybe I can :D Mate I have the same problem.... Did it settle in the box or did it fall apart? Or was it something else after all?
The discussion revolves around a knocking sound from the engine of a VW Passat B6 1.9 TDI when the clutch is pressed. The user initially reports the sound occurring both when the clutch is lightly pressed and fully depressed, with the noise being audible only from outside the vehicle. Responses suggest that the issue may stem from a broken pressure plate, worn transmission cushions, or problems with the dual mass flywheel. After replacing the pressure plate and clutch, the knocking persists, particularly when the clutch is pressed halfway, accompanied by vibrations and jerking in lower gears. Further suggestions include checking the clutch thrust bearing, transmission components, and potential crankshaft play. The user ultimately concludes that the transmission may be the source of the problem and is considering further mechanical evaluation.
