VW Passat B6 2.0TDI CBAB No Start Issue & Lost Communication with CDP+ Tester, CAN Gateway Module
waju12 12363 6
  • CAN Gateway pin 14 has reversed ignition voltage
    #1 16270916
    waju12
    Rate: 154
    I can't run the Passat B6 2.0TDI CBAB, it turns, but it doesn't start. In addition, I can not even connect to the CDP + tester, no communication with any driver. I checked the power supply to the CAN Gateway module, and I was surprised. Pin 1-ground, 2-battery power supply (12V,) pin 14-power supply from the ignition. There is constant power from the battery, but when the key is removed the voltage at 14 pins is present, and when you press the key the voltage disappears. Has anyone had a similar problem?
    Thank you in advance and best regards
  • #2 16271008
    lugi666
    Help: 17
    Rate: 158
    And can CANy reach OBD?
    I had a similar case and the car had anti-theft protection.
  • #3 16271022
    waju12
    Rate: 154
    Wires from gateway to connector? are coming up, and could there be a problem on power line 15? because when the key is removed the power supply is on and the voltage disappears when the key is pressed. And can you say something more about this security?
  • #4 16271423
    piotrekwoj1
    Help: 947
    Rate: 3433
    And how do you connect, since cdp + needs power + on pin 16 and ground on 4.5.
  • #5 16271459
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Put the OBD plus socket on pin 1 and then diagnose.
    At the time of diagnosis, it should be + 12V on pins 1 and 16 in OBD.
  • #6 16275168
    waju12
    Rate: 154
    Hello. power to the connector comes in, the problem was the can module itself - it was damaged, after replacement I was able to connect to the engine and the program detected such errors: VW Passat B6 2.0TDI CBAB No Start Issue & Lost Communication with CDP+ Tester, CAN Gateway Module
    Does anyone know where to look? The car still does not start.
    best regards
  • #7 16275203
    grala1
    Help: 1495
    Rate: 5052
    It's strange because the engine controller has K communication, the rest is CAN.
    Does the fuel pump in the tank work?
    From the description of the errors comes a problem in its control.
The discussion revolves around a VW Passat B6 2.0TDI CBAB that fails to start despite turning over. The user reports an inability to connect to the CDP+ tester, indicating a communication issue with the CAN Gateway module. Initial checks show proper power supply to the module, but an anomaly occurs where voltage at pin 14 disappears when the ignition key is pressed. Responses suggest potential issues with the anti-theft system, wiring from the gateway to the connector, and the need for proper power connections to the OBD socket. The user later identifies a damaged CAN module, which was replaced, but the vehicle still does not start. Further inquiries focus on the engine controller's communication type and the functionality of the fuel pump, indicating possible control issues.
