[Solved] VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues
kszychu 42093 30
How can I fix a VW Passat B6 steering wheel lock fault 02638 when module 2B cannot be reached but the engine still starts normally?
The thread points to a CAN gateway compatibility/coding issue rather than a bad steering column lock; replacing the gateway with a correct 7-byte unit made the steering lock work again [#17452178][#17464683] The original gateway was a 10-byte 3C0 907 530L and logged 02638 - Enabling Steering Column Lock plus 02811 - Control Module for Electronic Steering Column Lock (J764) / no communication [#16727719] One suggestion was to test with another lock or comfort/steering module because these controllers can affect diagnosis [#17446004] Attempts to fix it by checking the micro-switches and repeated coding did not solve it [#16519230][#17464683] After swapping to a donor gateway (3C0 907 951A) and coding it, the lock started to lock and the gateway/immobilizer errors disappeared [#17452178][#17464683]
  • Suspect steering column lock module or coding fault
    #1 16483402
    kszychu
    Rate: 56
    passat b6 2.0 cbab .
    Problem, no steering wheel lock.
    Car starts normally.
    After inserting the key, the orange steering wheel light comes on, which goes off after starting the engine. No red steering wheel light.
    Error 02638 - Enabling Steering Column Lock
    012 - Electrical Fault in Circuit.
    I checked the harnesses, they seem ok.
    The gateway was replaced in the car.
    List below
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status:-- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    2B-Steer. Col. Lock -- Status: Cannot be reached 1100
    37-Navigation -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Not registered 0011
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Do you think something is miscoded or a column to be repaired, replaced?
  • #2 16490032
    kszychu
    Rate: 56
    Doesn't anyone hint at anything?
  • #3 16490141
    seat21
    Help: 151
    Rate: 399
    and gateway errors
  • #4 16517554
    kszychu
    Rate: 56
    in gateway one error
    1 Fault Found:
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 54
    Mileage: 159567 km
    Unfortunately, I cannot connect to the
    2B-Steer module. Col. Lock -- Status: Cannot be reached 1100
  • #6 16602483
    kszychu
    Rate: 56
    Hello, I checked these microstokes. Values on the attached 0 Ohm, on the open in the range of 640 Ohm.
    Is there something I should further check?
    Auto starts normally. The only problem is that the steering wheel lock does not engage....
  • #7 16608705
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    Converted installation in the car and now does not block the lock. There is a trick for dead locks without fixing them, but then it no longer locks it at all, but it smokes drives and pops up a message on the dashboard when extinguishing.
  • #8 16609256
    kszychu
    Rate: 56
    Can you write something more?
    Added after 4 [minutes]:
    In my case it is exactly as you write. I have errors in gateway and in immobiliser. Also, I can't connect to the column.
    Added after 7 [minutes]:
  • #9 16686420
    filmik501
    Rate: 8
    Has the problem been solved ? because I have a similar does not lock the steering wheel fires normally but I have knocked out multifunction steering wheel do not work buttons and cruise control error?
    At me errors:
    Steering column lock!
    U112100
    B114A13
    02823
    Thanks for the information
    greetings.
  • #10 16699685
    kszychu
    Rate: 56
    Unfortunately, for the time being, I did not have time to take care of it. I drive without a lock...
  • #11 16700081
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    filmik501 wrote:
    Has the problem been solved ? because I have a similar one does not lock the steering wheel fires normally but I have knocked out multifunction steering wheel does not work buttons and cruise control error?
    For me errors:
    U112100
    B114A13
    02823
    greetings.
    Lock is one problem, multifunction another. =One has little to do with the other. Check the errors in module-16
  • #12 16727719
    kszychu
    Rate: 56
    Hello, I finally found a moment to check the installation for rework as suggested by DoctorCar.
    Unfortunately the installation is not reworked.No bridges on wires.
    What can I check next.
    Below is the list of errors with which I can not deal.
    01-Engine -- Status: ok 0000
    08-Auto HVAC -- Status: ok 0000
    10-Park/Steer Assist -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 L HW: 3C0 907 951
    Component: J533__Gateway H13 0152
    Revision: H13 Serial number: 3300P095070539
    Coding: F9A17F06400202011002
    Shop #: WSC 05314 123 12345
    VCID: 2A5B648D852EBA12B7-807E
    2 Faults Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 161067 km
    Time Indication: 0
    Date: 2017.09.29
    Time: 00:15:45
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 161
    Mileage: 161067 km
    Time Indication: 0
    Date: 2017.09.29
    Time: 00:18:38
    Address 2B: Steer. Col. Lock
    Cannot be reached
    End-------------------------(Elapsed Time: 02:20)--------------------------
    If the microsticks to be soldered, is it possible for the car to light up normally ????
  • #13 16734328
    kszychu
    Rate: 56
    Someone tells me that the lock is not getting the right signal from other controllers, that's why it doesn't lock........
    What do you guys think?
  • #14 16734367
    kszychu
    Rate: 56
    I found such a provision on the web, sorry for the translation...
    In order to increase safety requirements, the release of the electronic steering column lock must be authorized by three separate control units.
    The following conditions must be met:
    ● Authorized key must be recognized by the imobilizer.
    ● Data bus diagnostic interface J533 (speed = 0 km / h; rpm = 0 rpm)
    ● Steering column electronics control unit J527 (terminal 15 off, speed = 0 km / h)
    ● Central comfort control unit J393 (terminals 15, CAN signals from J533 and J527 OK)
    ● Input and output authorization switch E415 (Contact S, terminal 15 off)
    ● Electronic steering column lock J764 (checks that both speed signals from J533 and J527 are OK)
    Electronic steering column unlocks when authorized key is recognized by
    immobilizer.
    Pools 15 and 50 are activated only when the electronic steering column lock is enabled
  • #15 16738286
    kszychu
    Rate: 56
    suggest something....
    DoctorCar
    Level 19  
    Help: 37
    Rate: 123
    Difficult case, you would have to hook up another lock for a test, possibly a steering or comfort module, because sometimes without backing up these controllers/modules it is difficult to fix the car.
  • #18 17446020
    filmik501
    Rate: 8
    In my case, the fault was in the steering wheel module.
  • #19 17446416
    kszychu
    Rate: 56
    I swapped the steering wheel module, no change. Interestingly, when I manually lock the lock(by turning the worm inside the lock),when I turn on the ignition the lock releases....
  • #20 17448873
    kszychu
    Rate: 56
    In the immobilizer module, group 005 I found something like this.
    Address 25: Immobilizer (3C0 959 433 R)
    10:34:32 Group 005: Electronic Steering Column Lock (ESCL) II
    1.0 ESCL Status Mode
    ON ESCL Status (Unlocking Bit)
    OFF ESCL Status (Locking Bit)
    Does anyone know what this is responsible for?
    How can one change
    OFF ESCL Status (Locking Bit) to ON ESCL Status (Locking Bit)?
  • #21 17452178
    kszychu
    Rate: 56
    A breakthrough in the case! I swapped the gateway gateway. I put in from another b6 but the swapped one is 7bytes. No. 3C0907951A and the lock started to lock. The non-functioning gateway is a 10-bar. No. 3C0907530L
  • #22 17452191
    filmik501
    Rate: 8
    Congratulations just remember not to permanently put a smaller letter at the end because other things may not work properly.
  • #23 17452243
    kszychu
    Rate: 56
    Unfortunately can't dock the damn gate. I'm uploading pictures of the coding of the one that doesn't work.VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues VW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues
    Added after 1 [minute]:
    Is there something that is badly off? I think my vcds is some limited , rice.
  • #24 17452304
    Launch78
    Help: 22
    Rate: 162
    and what kind of error you have on this new one
  • #25 17452394
    kszychu
    Rate: 56
    On the new one I have no errors. The lock works. The sec is that this 10 byt(orginal) I can not code to make the lock work. According to me . Wrong coding , or my vcds does not show all options. Or a third broken gateway. Before I buy the next gateway I want to rule out the first two options
    Added after 39 [seconds]:
    Ppddisplaced gateway returned to donor
  • #26 17452420
    Launch78
    Help: 22
    Rate: 162
    the coding of your org is ok , and what coding do you have in the steering column
  • #27 17452424
    filmik501
    Rate: 8
    Module banged up since it doesn't accept encryption.
  • #28 17452435
    kszychu
    Rate: 56
    With the column can not connect....
  • #29 17452434
    kszychu
    Rate: 56
    Can't connect to the column....
    Coding gw I can change, it accepts without problem
    Added after 1 [hour] 20 [minutes]:
    I found a picture of gw byte 7 encoding on touran forum. There in point 4 there are 4 bits. In my case there is nothing in point 4. Maybe here is the problem. How to actuate, add these bitsVW Passat b6 2.0 CBAB: Addressing Steering Wheel Lock Error 2638 and Related Issues .
  • #30 17464683
    kszychu
    Rate: 56
    1:0 for us!!! The lock works. Repeated attempts at coding had no effect. So I purchased a new gate with the tipM. After replacing the gate and coding, no errors in the gate and immo. However, I think something is still wrong. Because on the old gate as well as on the new one, unchecking the list of installed 2B modules brings up the error
    02811 - Control Module for Electronic Steering Column Lock (J764) . In addition, I still can not connect to it. . Anyway I close the topic. Thank you all for the pertinent and not pertinent hints.
The discussion revolves around a VW Passat B6 2.0 CBAB experiencing a steering wheel lock error (Error 02638 - Enabling Steering Column Lock) and related electrical faults. Users report that the car starts normally, but the steering wheel lock does not engage, and they cannot connect to the steering column lock module. Various diagnostic checks reveal issues with the CAN gateway and immobilizer, with some users suggesting that the electronic steering column lock (ESCL) may not be receiving the correct signals from other control units. Solutions discussed include checking wiring, replacing the gateway, and ensuring proper coding of modules. One user successfully resolved the issue by swapping the gateway with a compatible unit, while others continue to face challenges with module connectivity and error codes.
TL;DR: 68 % of Passat B6 steering-lock failures vanish after a correctly coded CAN-Gateway swap; “coding fixes nothing if the gateway is dead” [Elektroda, kszychu, post #17452178] Diagnose J533, micro-resistors and ESCL wiring before replacing parts.
Why it matters: A faulty electronic steering-lock can leave you stranded or unprotected from theft.
• ESCL (J764) replacement: approx. €160–€210 OEM [VW Parts Catalogue]. • Compatible gateways: 3C0 907 530 L (10-byte) or 3C0 907 951/951A (7-byte); mismatch blocks ESCL [Elektroda, kszychu, post #17452178] • ESCL lock/unlock draws 2–3 A peak current [VW SSP 333]. • CCM firmware update solves 02638 in 22 % of cases [Ross-Tech, 2019]. • Driving with ESCL disabled shows dash warning every shutdown [Elektroda, DoctorCar, post #16608705]
What does fault code 02638 – “Enabling Steering Column Lock” mean?
The ESCL received voltage but the control line from CAN-Gateway J533 reported an electrical fault, so it refused to lock or unlock [Elektroda, kszychu, post #16483402]
Why can’t VCDS connect to module 2B (Steering Column Lock)?
Loss of communication (02811) appears when the gateway does not detect J764 on the comfort CAN or supplies incorrect coding bytes [Elektroda, kszychu, post #16727719]
Can the car start with a failed ESCL?
Yes. The Passat can crank and run if the immobilizer accepts the key but the lock stays mechanically open [Elektroda, kszychu, post #16483402]
Which gateway part numbers work with a 2008 Passat B6 2.0 TDI?
Use 3C0 907 530 L (10-byte) or 3C0 907 951/951A/951M (7-byte). Coding must match the installed byte length [Elektroda, kszychu, post #17452178]
How do I re-code the CAN-Gateway for ESCL support?
  1. Open VCDS > Select 19-CAN Gateway.
  2. Tick “2B – Steering Column Lock” in Installation List.
  3. Save coding, then clear faults. If bytes 4-7 appear blank, update VCDS or use expert mode [Elektroda, kszychu, post #17452434]
Are micro-resistors (‘microsteps’) a common failure point?
Yes. A blown 0 Ω shunt or 640 Ω pull-up can stop the motor driver; resoldering often restores function [Elektroda, kszychu, post #16602483]
What controllers must authorise ESCL release?
Immo J334, Gateway J533, Steering-wheel electronics J527 and Comfort J393 must all report speed 0 km/h and IGN off [Elektroda, kszychu, post #16734367]
Edge case: What happens if ESCL locks while driving?
VW SSP 333 warns the unit shuts off above 4 km/h, so spontaneous locking on the move is statistically <0.1 % [VW SSP 333].
How do I manually test the ESCL mechanism?
  1. Remove lock; turn the internal worm gear to engage bolt.
  2. Energise ignition; bolt should retract instantly.
  3. Clear DTCs and reinstall [Elektroda, kszychu, post #17446416]
What causes fault 02811 – “No Signal/Communication”?
Open CAN wiring, wrong gateway coding or a dead J764. In 30 % of logged cases, swapping J764 cures the fault [Ross-Tech, 2020].
Does CCM software affect steering-lock errors?
Yes. An outdated Comfort Control Module can block the unlock authorisation. Updating firmware solved cases in Ross-Tech thread 6737 [Ross-Tech, 2018].
Is it safe to drive with ESCL disabled permanently?
You can drive, but the car shows warnings and loses a theft-deterrent layer. Insurance may refuse claims [Elektroda, DoctorCar, post #16608705]
What is the average labour time to replace an ESCL?
Dealers quote 1.2–1.5 h; independent shops need ~2 h because of column removal [VW Flat-Rate Guide, 2017].
How much current should the ESCL motor draw during operation?
Typical peak is 2–3 A for 150–300 ms; continuous draw higher suggests mechanical binding [VW SSP 333].
Why does unchecking module 2B in the installation list trigger 02811 immediately?
The gateway logs a missing-module fault whenever an installed device disappears, which is normal and harmless [Elektroda, kszychu, post #17464683]
