[Solved] Passat b6 2.0Tdi Cr 2009 - The starter does not turn after inserting the key
SIERGIEJ4789 16500 2
  • #1 17265077
    SIERGIEJ4789
    Hello gentlemen
    I need help. Namely, he wants to start the car and nothing comes of it. After inserting the key into the ignition, there are 3 strange chirps, I press the key to make it spin and nothing happens. No reaction whatsoever. All fuses checked and it's ok. It happened overnight. Help!
    HERE a video with the problem
    [movie: b51d5196be] https://filmy.elektroda.pl/71_1528463900.mp4 [/ movie: b51d5196be]
    andrzej20001
    Help: 1574
    Rate: 6639
    Check with the light bulb if there is voltage on the starter solenoid on its thin wire, if so, the starter to be repaired.
  • #3 17265552
    SIERGIEJ4789
    Thanks. Problem solved. The automaton in the starter fell.
