Lenovo G50-30 BIOS Reset: Restoring Factory Settings with Damaged Matrix & D-SUB Monitor
Dez1 6939 8
  • #1 16274471
    Dez1
    Help: 35
    Rate: 39
    The problem is the subject. Lenovo G50-30 has a damaged matrix, that's why it was connected to the external monitor via D-SUB. After making and saving changes to the BIOS, it stopped displaying the image on the monitor. F10 without results.
    Please provide a hint on how you can restore the factory BIOS settings without access to the interface. Maybe there is a jumper or battery on the motherboard?
  • #2 16274510
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    The battery is.
  • #3 16274732
    Dez1
    Help: 35
    Rate: 39
    I located the battery. Unfortunately, it is soldered permanently. Anyone know a way to reset the BIOS other than by removing the battery?
  • #4 16274928
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    What is the problem with desoldering?
  • #5 16275184
    Dez1
    Help: 35
    Rate: 39
    The entire housing needs to be removed :( otherwise there is no access
  • #6 16275187
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    Then disassemble.
  • #7 16275482
    Dez1
    Help: 35
    Rate: 39
    boro1234567 wrote:
    Then disassemble.
    I understand that you do not know another method.
    Someone something?
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    Someone something?
    There is no other.
    I can't see the jumpers on this disc, I just watched it.
  • #9 16275750
    Dez1
    Help: 35
    Rate: 39
    Approx. When connected via HDMI, I could get an image on an external monitor, so I could enter the BIOS and reset the settings. Subject to close, thank you.
The discussion revolves around resetting the BIOS of a Lenovo G50-30 laptop that has a damaged display and is connected to an external monitor via D-SUB. The user seeks methods to restore factory BIOS settings without access to the BIOS interface, particularly since the battery is soldered and cannot be easily removed. Responses suggest that desoldering the battery requires disassembling the entire housing, which is cumbersome. Ultimately, the user found that connecting the laptop via HDMI allowed access to the BIOS, enabling the reset of settings.
