How to Force HUAWEI E5573 Router to Connect to a Specific BTS? - LTE Internet Issues
dejvo 15924 3
  • #1 16275110
    dejvo
    Hello, I have LTE internet with a plus with HUAWEI E5573 router, I usually keep it outside, because inside the apartment, the speed is about 10x lower, generally, to catch a good 50-60 mb / s transfer I have to restart it, i.e. pull the battery out, to get a good signal, the transmitter in my area is about 6 km in a straight line, the router connects to different BTS, and often there are different speeds, currently I am connected ... in total, I do not know to what BTS, on the map location shows me Głogów, but I have 400 km to Głogów. Is it possible to enforce a connection to a specific BTS? On the beta.btsearch .pl website, the CID and LAC of specific transmitters are given.
  • #2 16275150
    matek451
    Help: 4314
    Rate: 5708
    Enter your own location, check if your E5573 works https://dl.dropboxusercontent.com/u/1978345/E5186/E5186%20Toolbox_latest.rar or http://www.lte-anbieter.info/ltewatch/count_huawei.php? Datei = ltewatch_h these applications show LTE signal parameters, BTS data. Use them to force LTE800 and LTE1800. Plus uses the LTE1800Aero2 and LTE800sferii networks. Tests at home and outside, for this speed test. What were you guys doing when choosing Plus with the MiFi router worth PLN 100? All the more having problems with LTE coverage.
  • #3 16275170
    dejvo
    My location is Biszcza, E5186 Toolbox works, I just do not know how to force it, Router I have from a friend because, my fell, the Internet with plus I have, because in my village cable internet is overloaded and works poorly, overall I'm happy with this internet, only this connection is a bit of a nuisance.
    EDIT
    Tests to do at 800 and 1800? The one I see the best works on 1800
  • #4 16275369
    matek451
    Help: 4314
    Rate: 5708
    Show screenshots from Toolbox and speed test from LTE1800 and LTE800. You need to check the signal parameters and identify the BTs. The next permit for LTE1800aero2 is in Biszcza (the mast of Plus for Colombia, the road to Księżopol.) There is also permission for LTE800sferia, how far do you have to go?
