Huawei B528s - Forcing BTS: Manual Router Configuration with Programs & Techniques
roseus36 4641 5
  • #1 16877855
    roseus36
    Is there any program to manually force BTS to the router in question?
  • #2 16878099
    matek451
    Help: 4314
    Rate: 5708
    It is not possible to force a connection to a specific BTS. This can be done with a directional antenna with narrow beam angles. Of course, BTSs have to be in different directions. In your case, forcing the LTE band allows you to connect to different BTSs. There is LTE800 on one and LTE1800 on the other, although you would have to check whether LTE800 T-Mobile does not work at Nakielska.
  • #3 16885290
    roseus36
    Could you recommend me an external antenna for this modem. About 1km to BTS, the modem at the window is about 10-15 mbps, exposed outside the window is 30-38 mbps so I think it's worth it ... by the way, I did not know that the difference is so significant ... window 100m away from me and reaches 50mbps calmly without antenna .. strange.
  • #4 16885943
    matek451
    Help: 4314
    Rate: 5708
    And which LTE band do you want to use? Check if you are connecting to LTE1800 or LTE800 outside, and force LTE1800 = 800. And you don't know if your neighbor uses the same BTS and bandwidth. there is a strange thing in your situation because LTE1800 NW is confirmed on Nakielska and LTE800 on BTS Szubin-Wieś.
  • #5 16886570
    roseus36
    by the number of what will I know what I'm connecting with? :)
    Loncid? enbid?
