VW Passat b6 2006 - Single Door Opening with Remote, Others Accessible from Inside
Piotrssg 7566 7
  • #1 16278523
    Piotrssg
    Hello everyone for the first time ;)
    I have such a problem, when I open VW Passat with the remote control, only the right rear door opens and the driver's door shows that the car is closed. It cannot be opened with this button and I have to open all doors from the inside. There is no problem with closing, because they all close. Anyone know what this may be about?
  • #2 16279653
    actin
    Help: 187
    Rate: 799
    Have you tried re-encoding the key?
  • #3 16280801
    Piotrssg
    No, but why should it be decoded, I have two remotes and the same
  • #4 16280841
    daw126p
    Help: 7
    Rate: 14
    Try to adjust on the cables, similar to my Honda.
    Moderated By CameR:
    Reg. 3.1.11. Don't post messages that add nothing to the discussion. They are misleading, dangerous or do not solve the user's problem.
  • #5 16282977
    lookashECL
    Help: 8
    Rate: 60
    Or a cold February
  • Try double-pressing unlock for all doors
    #6 16283520
    majkel65
    Maybe press twice ... for me, one press opens the drivers ... when I double-click all of them
  • #7 16287480
    Piotrssg
    Twice gives nothing :) I wonder why it shines from the inside that the car is locked on a button
  • Intermittent driver door lock fault after long idle
    #8 21573403
    Lukacrazy1332
    I have a similar problem and zero response on the forum on FB. Passat B6 when the alarm is disarmed it unlocks all locks except the driver's door. Once I tilt the window and open it from the inside, the lock works fine. I should add that the lock light on the door lights up orange, when opened from the inside it lights up red. Is the lock to be replaced? I would add that when it sits for two or four weeks, everything works fine. Do you guys have any ideas?
A VW Passat B6 2006 exhibits an issue where only the right rear door unlocks via remote control, while the driver's door remains locked and can only be opened from inside. Closing all doors remotely functions correctly. Suggested troubleshooting includes re-encoding the key fob, checking and adjusting door lock cables, and verifying remote button press sequences (single vs. double press). Similar cases report the driver's door lock light showing different colors (orange when locked, red when opened from inside) and intermittent functionality after extended inactivity. Potential causes include faulty door lock actuators or wiring issues affecting the driver's door locking mechanism.
