vw passat b5 - windows not working, central locking with remote control and remo
Fanbmw 10002 6
  • #1 16639805
    Fanbmw
    Rate: 22
    today the opening and closing with the remote control did not work, the windows do not work, yesterday I tried to replace the slides of the passenger window and when I unscrewed the lock it locked (I can not close the door) I turn the key and nothing zero reaction.
  • #2 16639812
    robokop
    Help: 1763
    Rate: 6372
    Unplugged plug, broken beam. Everything about Passat b5 has been written in this forum.
  • #3 16639827
    Fanbmw
    Rate: 22
    what plug I have my right door dismantled, the door is locked vw passat b5 - windows not working, central locking with remote control and remo vw passat b5 - windows not working, central locking with remote control and remo
  • #4 16639845
    Heinzek
    Help: 554
    Rate: 494
    I understand that the door is locked and locked with a central lock. Cannot open the door handle inside.
    Does the handle work but the lock will not unlock.
  • #5 16639847
    Fanbmw
    Rate: 22
    the door cannot be closed because it is locked, I will check if it can be opened from the inside
  • #6 16639856
    Heinzek
    Help: 554
    Rate: 494
    It happens that when you slam such a locked door, the lock cannot unlock itself, then you can help it with a tool. i.e. open with the handle inside and help unlock with a screwdriver.
    When you pull the door handle inside and the bolt in the door slides out and retracts, you can't unlock the lock like that. It must be opened using the central.
  • Passenger door lock does not respond to key
    #7 16639918
    Fanbmw
    Rate: 22
    I managed to unlock using the inside of the door handle, there remains a problem with the windows not working, opening and closing from the remote control, because closing the windows and opening with the key works (like inserting the key to the door and the lock, the windows close or open)
    Added after 3 [hours] 30 [minutes]:
    but the passenger's lock does not respond to the key does not open or close
The discussion revolves around issues with a VW Passat B5, specifically related to non-functional windows and central locking via remote control. The user initially reported that the remote control for locking and unlocking the doors was unresponsive, and the windows were inoperable. After attempting to replace the passenger window slides, the door became locked and could not be closed. Responses included troubleshooting steps, such as checking the door lock mechanism and using tools to assist in unlocking the door from the inside. The user later managed to unlock the door but continued to face issues with the windows and remote locking, noting that manual key operation still worked for closing and opening the windows.
