Passat TDI 2004: Rear Passenger Door Won't Open with Remote, External & Internal Handles
szczepczyk 14496 7
  • #1 16346515
    szczepczyk
    Hello. I can't open the rear passenger door. Neither the remote control nor the external and internal door handle. Cypek don't move. Even after releasing the parental lock, they won't open. The garage mechanic told me that there was only a repair option at Volkswagen. Is it true or is it nothing serious but a guy drove me? Please help if anyone knows what it could be or had the same problem. Thanks
  • #2 16348090
    ociz
    Help: 1379
    Rate: 3486
    Standard on these cars. You have to torment the lock until you can open it, then remove it, throw it in the trash and install a new one.
  • #3 16348344
    Hektar Zahler
    Help: 230
    Rate: 528
    The lock in B5 has a kind of disadvantage and I fix it on the bank from both sides as long as the calculation brings me a shame and the customer smiles. If not, there is nothing to talk about.
  • #4 16348606
    szczepczyk
    So it looks like you have to invest in a new castle ... Thank you very much for your help. best regards
  • Reposition metal hook and flush-fit outer door handle
    #5 16348853
    Hektar Zahler
    Help: 230
    Rate: 528
    I don't know what's new there, because I do as I do and I prefer to be sure of getting rid of the defect. You have to move this gingerbread as the arrow shows that the metal hooked on the plastic. Important - the outer handle must not protrude outwards or by a millimeter. In the front you can help the pilot by pushing back and forth, because it is unlocked in two, and I don't remember at the back.
  • #6 16348861
    andrzej20001
    Help: 1578
    Rate: 6668
    Hit your hands hard from the outside and try to pilot, let go. How do you get tired of upholstery, metal sheet out and strength entry. It is not easy. The first option is better. Insert new castle.
  • #7 16350979
    szczepczyk
    Today I tried to remove the cover outside to the right of the door handle because there is supposedly such a trigger and when you press it the lock should go down, but I got down because I would scratch the door in the spit. Thanks for any advice, I won't give up so easily.
  • #8 16351072
    Hektar Zahler
    Help: 230
    Rate: 528
    The anti-theft guard does not allow access to this jig. I won't say what to do with her anymore. How does it work on the other side it is better not to preview and earn some extra money ..
The discussion revolves around a 2004 Volkswagen Passat TDI with a malfunctioning rear passenger door that cannot be opened using the remote or internal/external handles. Users suggest that the issue is likely due to a faulty lock mechanism, which may require replacement. Some responses indicate that the lock design has inherent disadvantages, and a new lock installation is the most reliable solution. Various methods to troubleshoot the issue are discussed, including manipulating the lock and attempting to access the mechanism, but these may lead to further complications or damage. The consensus leans towards replacing the lock as the most effective resolution.
