VW Passat B5 (2000) - Central Locking Issue: Remote Control & Trunk Lid vs Key & Door
qbass01 10068 4
  • #1 16634920
    qbass01
    Rate: 21
    Today in my 2000 belt there was such a problem: opening and closing the door with the remote control works only in the trunk lid. The door does not respond to the remote control. However, when I turn the lock with the key, the central lock works only in the door. The tailgate does not react then and neither closes nor opens. Are these symptoms of the comfort module or another reason?
  • #2 16634955
    Elektron 17
    Help: 6
    Rate: 129
    Look under the rug under the driver's feet
  • #3 16635004
    qbass01
    Rate: 21
    I will definitely look, but I would be grateful buddy if you gave me information what exactly should I look for there?
    Edit
    I looked into the comfort module. After cleaning the contacts and reconnecting the module, the following situation: The door almost always opens and closes with the remote control, but the rear right door does not respond to the remote control at all. They only react to the key.
  • #4 16635106
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    For the door, it doesn't really matter if they are locked with a remote control or key.
    Dry module, dry floor?
    Does the door LED flash when closed?
    Connect to a computer and read the errors from the comfort module.
    Maybe a problem in the microswitches in the locks, with power supply or communication with the comfort module.
  • #5 16636261
    qbass01
    Rate: 21
    Dry in the module. Liner slightly damp at the height of the pedals. There is no water on the floor. As of today: After stopping all night at the first attempt to open from the remote control, it was heard that the locks were moving, but no door opened. When trying again, all doors unlocked and at present all doors and the tailgate react to the remote control (closing / opening).
