No Image from PC to Samsung PS51E450 TV via HDMI Post-Windows Startup: Solutions & Drivers
abek 15069 9
How can I get a Samsung PS51E450 to show a PC picture over HDMI after Windows starts when only the POST screen and Windows logo appear, but then the TV goes blank and is not detected as an extra monitor?
Try forcing Windows to use the HDMI display with Win+P and check the graphics settings for an additional monitor/HDMI output, because the TV may simply not be enabled as a second screen [#16285098][#16299726] On Samsung sets, also check the input/source settings: if there is a DVI-HDMI input option, rename the source to "DVI PC" in the tools/settings menu, which reportedly fixed a similar Samsung-to-PC HDMI problem and allowed a higher-resolution signal [#16289913] Another suggestion is to verify the maximum resolution supported by both the PC and the TV and, on some TVs, set the HDMI port version for computer use in the HDMI options [#16298594]
  • #1 16284883
    abek
    Rate: 49
    Television: Samsung PS51E450.
    HDMI connector.
    Problem: after starting the image is transferred in POST window mode and Windows logo (640x480x60p). After starting the system - no image. Driver applications (the latest version) do not recognize the connected TV. I reset the TV. The same on both HDMI connectors. Connecting another computer - the same. When the TV is running, when I disconnect the HDMI cable (I have also tested 2 others), Windows will report the reconnection with sound - but the image is missing.
    Thanks for the help
  • #2 16284971
    highlanderus
    Level 30  
    Help: 174
    Rate: 186
    Which computer is connected to the TV. If this is a laptop, look on the keyboard for the pictogram showing the screen and probably in combination with the FN key you can enable image transfer.
  • #3 16285031
    abek
    Rate: 49
    The computer is a PC.
  • #4 16285052
    highlanderus
    Level 30  
    Help: 174
    Rate: 186
    What kind of graphics do you have in it?
  • #5 16285062
    abek
    Rate: 49
    Intel Q965 integrated.
  • #6 16285098
    highlanderus
    Level 30  
    Help: 174
    Rate: 186
    I assume that the drivers installed properly. Look for the additional monitor option via HDMI in the graphics settings.
  • #7 16285256
    abek
    Rate: 49
    On the Win10 laptop it does not detect an additional device (TV). Switching with the FN + keys ... does not work. I thought that the HDMI ports were damaged, but in total the image displays (at the computer startup).
  • #8 16289913
    Tymon_HS
    As I connected Samsung to a PC via HDMI, I also had a problem, maybe it's the same.
    If you have DVI HDMI input in the monitor, connect there. Click the remote control settings menu to enter the monitor (at my source).
    Arrows to input with connected monitor, settings / tools / tools and change the name to DVI PC. Then I just started the monitor from the same computer, using the same cable to receive a higher resolution signal.
    Strange, but it helped me ;)
  • #9 16298594
    KOCUREK1970
    Help: 3867
    Rate: 5500
    @abek
    And what is the maximum resolution of the image supported by this computer and this tv?
    On some TVs, first set the port versions for the computer in the HDMI option.
The discussion revolves around a user experiencing issues with their Samsung PS51E450 TV not displaying an image from a PC via HDMI after the Windows startup. The user reports that the image is visible during the POST and Windows logo phases but disappears once the operating system loads. Despite using the latest drivers and testing multiple HDMI cables and ports, the TV does not recognize the PC as an additional display. Suggestions include checking graphics settings for additional monitor options, using the Win + P shortcut for display settings, and configuring the TV's HDMI input settings to recognize the PC. One user shared a solution involving changing the input name to DVI PC to achieve a higher resolution signal.
