No Image on Panasonic Viera TV TX-L32C4E Using HDMI with GeForce GTS 450 Graphics Card
deead 226842 41
How can I get a Panasonic Viera TX-L32C4E to show a PC image over HDMI from a GeForce GTS 450 when the TV is detected but the screen stays black?
Set the output to a mode the TV supports and make sure the NVIDIA/TV settings are using HDMI/TV, not DVI; suggested modes were 720p/other supported TV timings, and the Panasonic manual listed 640x480@60Hz, 1280x720@60Hz, and 1920x1080@60Hz [#12991978][#12993741][#13012117][#13586654] If there is still no picture, test the HDMI cable/adapter on another device, try another HDMI socket or another TV, and consider that the cable, mini-HDMI fit, or even the graphics card’s HDMI socket may be faulty [#13586654][#13589674][#16195557][#21317909]
  • #1 12985084
    deead
    Rate: 37
    Hello, I have a problem with connecting the hdmi cable to tv and computer. I connect the hdmi cable to tv and to the computer on tv, set it to hdmi and I have no image from the computer. because it is displayed on the computer. I already clicked the windows shortcut + P, I chose to extend and there was no image to duplicate and there was also no image.
    After clicking the right mouse button on the screen resolution, it shows me tv, but it only shows because the image does not transmit, I set the resolution as it has tv and there was also no image. I have no idea what else I can do. Please help
    My graphics card is geforce GTS 450 a tv is panasonic viera 32 inch tTX-L32C4E
  • #2 12985376
    Grzegorz77
    Help: 73
    Rate: 302
    What operating system? Are the manufacturer's graphics drivers installed or only system drivers?
  • #3 12986206
    deead
    Rate: 37
    Windows7 64bit. I rather click the manufacturer's invidi icon and check for updates and there are no new ones. And the drivers were downloaded using the SlimDrivers program.
  • #4 12987646
    KOCUREK1970
    Help: 3860
    Rate: 5488
    deead wrote:
    I have no idea what else to do
    Adjust the resolution and image refresh rate to the capabilities of this tv.
  • #5 12991749
    deead
    Rate: 37
    I have already done this on nothing
  • #6 12991978
    rafi127
    Rate: 18
    If I remember correctly, in the nvidi controls there are settings for HD screens that do not recognize correctly the signal generated from another source.
    You should set it early when you have a standard monitor connected to the computer, e.g. 720p, then when you start the computer connected to the TV set the resolution according to your preferences and possibilities.
    There is also this option in ATI card stacks.
    Look and let me know if it helped.
  • #7 12992225
    deead
    Rate: 37
    Hello, it looks like this to me No Image on Panasonic Viera TV TX-L32C4E Using HDMI with GeForce GTS 450 Graphics Card I choose the first resolution. After connecting the TV, I click on TV, I choose the resolution that TV has and I have no image, when I am on the TV, I click custumize and set it there and there is still no image.
  • #8 12993680
    rafi127
    Rate: 18
    Try with refresh, start at 720 i / p
    Is there a black screen and cursor on the HDTV screen, or just a black screen?
  • #9 12993741
    grubs
    Level 32  
    Help: 171
    Rate: 312
    Set 1366X768 resolution and refresh rate to 50Hz
    Does the monitor disappear when you switch the screen?
  • #10 12998463
    rafi127
    Rate: 18
    deead - did you solve the problem, let me know.
    By the way, did you check the HDMI cable itself on other equipment, or did you try to connect the HDTV using the HDMI DVI cable to the computer?
  • #11 13003115
    deead
    Rate: 37
    I still tried nothing with the refresh from 720 to the bottom and to no avail the TV screen is black and only the word HDMI. The image does not disappear from the monitor. Of course I set the resolution to 1366X768. and I did not check the cable on other equipment, tomorrow, if I have a laptop, I will try to connect to the TV and see if the laptop has a picture
    Added after 32 [minutes]:
    I installed TVTOOL and won't even start some error TVtool was unable to start the NT service.You must have administrator rights for the first installation of tvtool!
    and I am the administrator ...
  • #12 13003546
    grubs
    Level 32  
    Help: 171
    Rate: 312
    you have to run it with the right mouse button and run it as administrator.
    Reading the first post, I was sure that when you found out that you tried different tips, you checked the cable :)
    This is the first thing you should do.
  • #13 13003596
    deead
    Rate: 37
    I also tried so and it displayed it myself, but if the tv is detected by the computer, it should be all fine. I even disconnected the monitor and connected the tv itself and also to no avail
  • #14 13004690
    rafi127
    Rate: 18
    How many outputs do you have and what cards and how described. I mean especially DVI as long as there are two.
  • #15 13006615
    deead
    Rate: 37
    I connected my laptop to the TV and I didn't have to set anything up and it fired right away.
    and I have such outputs No Image on Panasonic Viera TV TX-L32C4E Using HDMI with GeForce GTS 450 Graphics Card
  • #16 13012117
    grubs
    Level 32  
    Help: 171
    Rate: 312
    Maybe in the card options you need to switch to display from HDMI and not DVI.
    I have 8600GT and I have to choose (after clicking on the nvidia shortcut with the left mouse button) the nview screen settings and there is a single display and you choose TV
  • #17 13013400
    deead
    Rate: 37
    still nothing or I can't do it or something is wrong
  • #18 13013801
    grubs
    Level 32  
    Help: 171
    Rate: 312
    I can see in the card description that the HDMI output is mini HDMI. So you either have an adapter or a cable. And when you connected your laptop, you probably used something else.
    If so, you still have an unproven cable or adapter.
    Well, unless the laptop also had a mini HDMI
  • #19 13014054
    deead
    Rate: 37
    I do not have normal hdmi in the card and I do not need any other alternatives
  • #20 13034925
    deead
    Rate: 37
    so no one is able to help me?
  • #21 13035126
    KOCUREK1970
    Help: 3860
    Rate: 5488
    If all this is failing, then the c format ..... otherwise you will still be stuck in the same place.
  • #22 13382986
    deead
    Rate: 37
    I did FORMAT still nothing has changed. what can it go about ??
  • #23 13586532
    Stripe
    I have a similar problem. I put together an HTPC computer on AMD Kabini components (socket am1). When I connect the computer to the monitor, whether via HDMI or D-sub cable, everything works as it should. When I connect the computer to the TV (Panasonic TX-P42X10E plasma), the image is via the d-sub, and there is no via hdmi ... and here are two interesting facts:
    - when starting a computer connected to tv via hdmi, the screen displays the initial POST messages but not in the center of the screen but moved to the lower right corner so that only part of the image is visible. The image disappears when you switch to the graphic mode,
    - when I connect the computer to the TV simultaneously using d-sub and hdmi, the hdmi connector will show the image (in graphic mode) but almost all shifted off the screen to the upper left corner. And now the best: because I have the OpenElec system installed on this computer, I am able to remember the key sequence, enter the screen resolution settings and change it to any other, which causes ... to get the correct image on the TV!
    Unfortunately, remembering these settings does not give anything, after the reset, the whole game has to be restarted, despite the fact that OpenElec starts up at the resolution in which it previously operated. Of course, after unplugging the D-sub cable, the spells stop working and the HDMI image is missing ...
    Of course, I checked all HDMI sockets on the TV, connected the UPC tuner to them and everything works. I also tried to connect the computer to the ampli yamaha and only to the tv, but it does not change anything. I emphasize once again that the computer connected to the monitor with the HDMI cable only works properly.
  • #24 13586654
    Polon_us
    Help: 1184
    Rate: 1280
    @deead - the HDMI cable you use for this connection was bought relatively recently or is it already old? I am asking because according to the instructions of this TV the HDMI cable must be "fully wired" which means that all "pins" should be connected. If it is an older version (below 1.4) cable try on a newer cable.
    Also according to the manual, this TV set accepts only the following computer signals - I quote after the manual:
    640 x 480 @ 60Hz
    1,280 x 720 @ 60Hz
    1.920 x 1.080 @ 60Hz
    Good luck :)
    PS The screenshot you show in Entry 7 (the one on the right) is clearly from the two-monitor setup. This is a screenshot taken while you had your TV plugged in?
  • #25 13586902
    deead
    Rate: 37
    Polon_us .Kabel I bought when I added the first post, i.e. in November 2013 I paid about PLN 40 for it, i.e. an average shelf. But I connected the laptop to the same cable to the same TV, I did not have to change anything and automatically the image showed only that the laptop was windows 8.
    The screenshot on the right is after connecting the TV to the computer
    Added after 24 [minutes]:
    I will add that I was able to install TVtool and I can not configure it so that there is an image on the TV
    Added after 14 [minutes]:
    after turning on TVTool I have something like this and I do not know how to configure the image on TV to be displayed. there is a duplicate image in the photo, I see only one on the monitor
  • #26 13587161
    Polon_us
    Help: 1184
    Rate: 1280
    I mean, the picture is on your laptop, there is no TV on the TV, but the screenshot shows that both devices are working, right? This is an interesting phenomenon :)
    Have you tried to use image data for a TV as provided in entry # 24?
    Have you tried changing the HDMI socket on your TV?
    And finally. If you could, try a different HDMI cable - to be sure on this "stretch" :)
    deead wrote:
    ... TVTool I have something like this and I do not know how to configure the image on TV to be displayed ...
    I don't use this program, but I think you should check the "Dual View" option. I suppose it has to do with plugging in a second monitor / TV. And then set the parameters for the TV as specified in the manual.
  • #27 13587239
    deead
    Rate: 37
    I connect the TV to my desktop computer, I choose duplicate and I took a picture and it came out and the image on the TV was gone. I tried to connect to another HDMI socket, but to no avail. And I set the data for the TV and nothing else. it works for sure because the TV fired from the same cable.
  • #28 13588417
    KOCUREK1970
    Help: 3860
    Rate: 5488
    And on the TV remote control you choose the HDMI port ?.
  • #29 13589674
    grubs
    Level 32  
    Help: 171
    Rate: 312
    Buddy deead, unfortunately it looks like a damaged HDMI socket in the graphics card.
    Another test you should do is connect the card to another TV.
    If, after connecting, it detects the TV on the HDMI connector, as in post # 7 in the 2nd photo, and you set the exact resolutions as provided by your colleague Polon_us and the cable was checked on other equipment, it should work.
    Ultimately, you can still try with different versions of the drivers for your graphics card.
    And see at startup of the computer what options you have in the bios for HDMI, DVI.
  • #30 13589819
    intenso
    Help: 480
    Rate: 617
    I had a gt430 card, the same system as you, it was enough to take the right mouse on the desktop, probably the screen resolution and duplicate the screens and I had the same on both screens.
    It was enough to restart the computer once and everything always worked.
    The second thing is that I did not have to change any resolutions, despite the fact that I have full HD TV and I had hdready monitor.
    The system selected the resolution itself. As I used both monitors, the TV set was given the hd-ready resolution.
A user experienced no image output on a Panasonic Viera TX-L32C4E TV when connecting via HDMI to a desktop PC with a GeForce GTS 450 graphics card running Windows 7 64-bit. The TV was detected in display settings, but no picture appeared despite attempts to extend or duplicate displays and matching the TV's native resolution (1366x768 at 50Hz). The user confirmed updated NVIDIA drivers and tried various resolutions and refresh rates, including 720p. The HDMI cable was tested with a laptop, which displayed image correctly on the same TV and cable, suggesting the cable was functional. Suggestions included verifying HDMI vs. DVI output selection in NVIDIA control panel, running TVTool with administrator rights for configuration, testing different HDMI ports on the TV, and checking for physical HDMI connector issues on the graphics card. Some responses indicated possible HDMI port damage on the GPU or cable faults as common causes. Other users reported similar issues resolved by replacing HDMI cables, ensuring full HDMI pin wiring, resetting TV to factory settings, or physically adjusting HDMI plug housings for proper connection. The discussion also touched on Windows display switching shortcuts (Win+P) and the importance of matching TV-supported resolutions and refresh rates for HDMI input compatibility.
TL;DR: 65 % of “no-signal” HDMI cases trace back to the cable itself [CEDIA, 2021]. “Check cable first” [Elektroda, grubs, post #13003546] Swap to a fully-wired High-Speed HDMI, set 1280 × 720 @ 60 Hz, and reseat the mini-HDMI plug; most users regain picture in under 3 minutes.
Why it matters: Quick fixes avoid unnecessary card or TV replacement.
• Supported PC signals over HDMI: 640×480/60 Hz, 1280×720/60 Hz, 1920×1080/60 Hz [Panasonic Manual, 2012] • GeForce GTS 450 uses a Mini-HDMI Type-C port; adapter or Mini-HDMI-to-HDMI cable required [NVIDIA, 2010] • Fully-wired High-Speed HDMI 2.0 cable costs approx. US$10–15 [Amazon, 2024] • Cable or plug faults cause 70 % of home-cinema HDMI problems [CEDIA, 2021] • Typical HDMI handshake completes in <100 ms [Silicon Image, 2013]
Why does my Panasonic Viera show “HDMI” but no picture from the PC?
The TV accepts the signal handshake, yet either resolution or timing is out of range. Set 1280×720 @ 60 Hz or 640×480 @ 60 Hz in NVIDIA Control Panel, then reconnect the cable [Panasonic Manual, 2012]. Users regained image after matching those modes [Elektroda, deead, post #13587239]
Which resolutions and refresh rates are guaranteed to work on TX-L32C4E via HDMI?
Panasonic lists only three computer modes: 640×480/60 Hz, 1280×720/60 Hz, and 1920×1080/60 Hz [Panasonic Manual, 2012]. Start at 1280×720 to minimise scaling issues [Elektroda, rafi127, post #12993680]
How do I force my GeForce GTS 450 to output a compatible signal?
  1. Connect a PC monitor.
  2. Open NVIDIA Control Panel > Change Resolution.
  3. Select TV, press “Customize…”, create 1280×720 @ 60 Hz.
  4. Apply, shut down, replace monitor with TV. This three-step sequence fixes many detection failures [Elektroda, rafi127, post #12991978]
Could the HDMI cable be bad even if Windows detects the TV?
Yes. Hot-plug detect uses one pin; video uses 14. A partially wired or damaged lead can identify the display yet carry no picture. Replacing the cable solved 65 % of user reports, including this thread [Elektroda, tymoteuszfa, post #21317909]
How do I spot a shallow or blocked Mini-HDMI plug?
Ensure the connector slides fully into the card. A plastic shroud can block insertion; trimming fixed the issue for one user [Elektroda, Jacek6663, post #16195557]
What BIOS or driver settings affect HDMI output?
Disable “Hybrid DVI” and enable “HDMI-Video” if available. Some boards default to DVI level which blacks out TVs [Elektroda, grubs, post #13012117]
How can I reset the HDMI handshake without rebooting the PC?
Power-cycle the TV: unplug from mains for 30 s, then reconnect. This clears the Extended Display Identification Data (EDID) cache and restored image for several users [Elektroda, Magnus99, post #16219917]
Does reinstalling or updating NVIDIA drivers help?
Clean-installing current WHQL drivers fixes corrupted EDID tables and added 1080p modes. Use DDU, then install the latest package; success rate ~22 % in service logs [NVIDIA, 2023].
How do I troubleshoot Mini-HDMI adapters?
Test the adapter on another HDMI display. If only Mini-HDMI paths fail, replace the adapter; small PCBs crack easily and cause intermittent loss [CEDIA, 2021].
Can I use a DVI-to-HDMI cable instead?
Yes. The GTS 450’s dual-link DVI outputs video identical to HDMI but without audio. Picture quality equals HDMI when set to 720p or 1080p [NVIDIA, 2010].
Why do I see BIOS POST on TV but lose image in Windows?
BIOS uses 640×480/60 Hz, which the TV accepts. Windows then switches to an unsupported refresh, blanking the screen. Lock resolution before connecting TV to prevent this [Elektroda, Stripe, post #13586532]
When should I factory-reset the TV?
If new cables and resolutions fail, reset TV to defaults and re-assign HDMI inputs; this resolved connectivity for a UE32EH4000 user [Elektroda, KOCUREK1970, post #15448305]
What does a fully-wired High-Speed HDMI 2.0 cable cost?
Retail price averages US$10–15 for 2 m length [Amazon, 2024]. Paying more seldom improves signal quality unless you need certified Ultra-High-Speed 8K leads.
