EINHELL BT BC 15 - Voltage Output Issues When Switching Between Settings
autocezar 11673 17
Why does my battery charger show only about 14 V on 24 V, 7 V on 12 V, and under 4 V on 6 V, and what part may be damaged?
The large green 40 W resistor is likely damaged; the original part is RX 20-40, 0.12 Ω, 5%, and if it has gone open/OL the charger can behave like this [#17592815] Replace that resistor first; one reply also notes the resistor was visibly cracked and should be the first thing to change [#16293339] The charger’s terminal voltage should not be judged unloaded, so test it with a battery connected and watch the charging current and voltage under load [#16285796][#16285942] In the example discussed, the output looked “strange” with no battery, but stabilized after connecting a battery, and the low-voltage fault was linked to the resistor, possibly after a battery with an internal short circuit damaged it [#17592815]
  • #1 16285776
    autocezar
    Rate: 15
    Rectifier as in the subject. After switching to 24V, a voltage of about 14V appears on the terminals, after switching to 12V - 7V, after switching to 6V - less than 4V. I am asking for advice, what could have been damaged?
    Best regards!
  • #2 16285796
  • #3 16285828
    autocezar
    Rate: 15
    12.4 V battery
    after connecting the voltage at the terminals 12.4V
    After unplugging about 7V
  • #4 16285942
  • #5 16286292
    autocezar
    Rate: 15
    YES THE LAYOUT IS SIMILAR BUT WE HAVE MORE HIGH GREEN RESISTOR
  • #6 16286801
  • #7 16293008
    autocezar
    Rate: 15
    the built-in ammeter shows nothing. The tip does not work
    The voltage measurement after 30 and 60 minutes gives the same values. 12.4V
  • #8 16293047
  • #9 16293208
    autocezar
    Rate: 15
    A resistor at low idle 690k when connected to the network indefinitely
    5.9V alternating voltage across the bridge
  • #10 16293295
  • #11 16293335
    autocezar
    Rate: 15
    Unfortunately, there are no subtitles, it is possible that they were once, but now there is nothing. It's also a bit cracked. Start by replacing this resistor?
  • #13 16293541
    autocezar
    Rate: 15
    Thank you for the hint, I will start by replacing the resistor.
  • #14 16339690
    mamkonto
    Help: 14
    Rate: 108
    Has the rectifier been started?
    A colleague brought the same rectifier, similar symptoms, after disconnecting the battery at the 8 V output, a damaged transistor.
  • #15 16339703
    Krzysztof Kamienski
    Help: 2033
    Rate: 5167
    About Jesus Christ Superstar ...... :D
    autocezar wrote:
    I'll start with replacing the resistor.
    And what is its value, as long as it is allowed to ask?
    mamkonto wrote:
    damaged transistor.
    Which one ??
    How measured ??
    To sum up, you made me laugh since the morning, Dear Group of Experts :D :D
  • #16 16340058
  • #17 16347322
    autocezar
    Rate: 15
    unfortunately it failed. I do not know what resistor needs to be replaced, what are its values. No markings on the resistor
  • #18 17592815
The discussion revolves around voltage output issues with the EINHELL BT BC 15 rectifier when switching between settings. Users report low voltage readings (14V at 24V setting, 7V at 12V, and less than 4V at 6V) and a non-functional built-in ammeter. Suggestions include measuring the charging voltage and current while connected to a battery, checking the green resistor and the alternating voltage across the bridge rectifier. A damaged rectifier is suspected, particularly due to the ammeter showing no readings and consistent low voltage measurements. Users recommend replacing the resistor, which is identified as a 0.12 ohm 40W component, and ensuring proper connections. The discussion also touches on similar issues with other models, indicating potential common failures in the rectifier design.
