Connecting the motor from the washing machine for a short time.
Eniu28 13758 4
  • #1 16286053
    Eniu28
    Please ę for help in pod la engine, namely, please ę here is that ś I told you kt about cables to kt about they belong to with y under la whether AE Yes that the engine is going L at high speed it is the engine from the washing machine B eco its name is arcelik.
    3.1.13. Publishing entries that violate the spelling rules of the Polish language, careless and incomprehensible.
    I corrected the text.
    Moderator Krzysztof Reszka
    • Connecting the motor from the washing machine for a short time. 1487347081540-866332148.jpg (1.16 MB) You must be logged in to download this attachment.
  • #2 16286204
    Grzegorz_madera
    Help: 268
    Rate: 1736
    Here you have everything: link
    PATAFIAN_PATAFIAN
    Conditionally unlocked
    Help: 38
    Rate: 54
    green-yellow - grounding
    black - phase
    blue - neutral
    If it does not start, you will still need a start capacitor between the phase cable and the gray cable.
    First make sure that the motor is powered with 230V voltage because not all motors from the washing machines were powered with such voltage.
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1624
    black - phase
    blue - neutral
    The picture clearly shows that this is a commutator motor where the capacitor is unnecessary. The capacitor is used only with cage motors.
  • #5 16315504
    Eniu28
    Ok, thanks to the gentlemen, the engine is racing.
    Greetings!
