Connecting Whirlpool Washing Machine Motor: Correct Wiring Diagram?
TheKocur 9714 2
  • #1 16450039
    TheKocur
    Rate: 11
    Hello, I recently removed the washing machine motor Connecting Whirlpool Washing Machine Motor: Correct Wiring Diagram? I wanted to connect it but I don't know how. Black and blue go to the brushes (to separate). Two gray ones go to the winding and there are 2 white ones (so thin) that go to something. (I didn't connect them)
    I connected red with one gray and blue with the other gray and so connected to the 12 V battery and it worked. When connected to 220 V, fuses struck. How should I connect it?
    Thanks in advance for your answer :)
  • #2 16450086
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2795
    TheKocur wrote:
    Hello, I recently removed the washing machine motor - Wiring diagram for a Whirlpool washing machine motor? I wanted to connect it but I don't know how
    Thread repeated here many times.
    TheKocur wrote:
    there are still 2 white ones (so thin) that go to something.
    For tachometric generator.
    It was a shunt motor operation.
    It is not surprising. The excitation winding has low resistance. This washing machine motor works as a serial - stator winding connected in series with the rotor (brushes).
  • #3 16450705
    TheKocur
    Rate: 11
    I close the topic. I have already connected
