Electrolux EHL6740FOK - A problem with connecting an induction hob
kaszus 3912 7
  • #1 16286541
    kaszus
    Rate: 13
    I am interested in buying an induction hob as in the subject (EHL6740FOK)
    I am not sure if I will be able to connect it with the cube that protrudes from the wall (photo)
    From the authorized service I got the answer that the device works only on 2 phases - 220-230V.
    I do not want to connect the hob to a normal socket because I have the whole kitchen in phase 1 and it will make no sense ...
    Please let me know if you can connect it or look for a 400V disc
    • Electrolux EHL6740FOK - A problem with connecting an induction hob kostka.jpg (74.31 KB) You must be logged in to download this attachment.
  • #2 16286626
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1623
    What is your 1- or 3-phase power supply in your home?
    To enjoy the benefits of warranty, the hob must be connected by a qualified electrician.
  • #3 16286646
    kaszus
    Rate: 13
    That the electrician is obviously natural, but I do not know if it can be connected at all :)
    I am attaching a photo of the fuse box - it may help to determine the power supply :) Electrolux EHL6740FOK - A problem with connecting an induction hob
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    From what you can see, you have a separate circuit for 3-phase electric kitchen power supply, everything is also okay. You can easily buy such a hob.
    zyzy52
    Help: 126
    Rate: 367
    It looks like you have a three-phase power supply designed to power such a cooker. This turned off fuse (it is described) indicates this.
  • #6 16286736
    kaszus
    Rate: 13
    This is since it is a 3-phase power supply - and the service writes that only 2-phase power supply is how to understand it?
    Connect only 2 phases to the disc and leave one free?
    I ask theoretically - I won't connect anyway but I would like to know :)
    Topolski Mirosław
    Help: 355
    Rate: 1623
    Leave it to the electrician because he is a specialist in these matters. In the documentation of the oven there is also a wiring diagram - on the other hand, from the 3-phase power supply you have derived 1-phase circuits.
  • #8 16286845
    kaszus
    Rate: 13
    ok - the most important thing is that you can connect the board to such a circuit :)
The discussion revolves around the Electrolux EHL6740FOK induction hob and its compatibility with a 3-phase power supply. The user seeks clarification on whether the hob can be connected to a 3-phase circuit, as the manufacturer's service indicated it operates on a 2-phase system (220-230V). Responses confirm that the user's setup appears to support a 3-phase supply, suggesting that the hob can be connected. However, it is advised to consult a qualified electrician for proper installation and to refer to the hob's wiring documentation for guidance on connecting the phases correctly.
