Electrolux EHI6340FOK Induction Hob: 3-Phase Connection Compatibility & 220-240V Voltage
3576 2
  • Three-phase hob uses separate phase feeds
    #2 17148862
    hobbysta92
    Home appliances specialist
    Help: 62
    Rate: 86
    Induction hobs are always powered from 220-230V, the manual should describe the method of connection. It is all about power distribution, the left and right sides are supplied from separate phases with a common neutral wire. Remember that the hob should be connected by a licensed electrician with an appropriate entry in the warranty card.
  • #3 17149947
