Electrolux ESL 65070 Dishwasher Not Turning On: Main Switch & Converter LNK304 Issues
bruno55 5853 3
  • #1 16287468
    bruno55
    Rate: 41
    Hello!
    I have a question about the dishwasher model above, it has stopped working, i.e. nothing is happening, it does not turn on, no lights are on. I would like to add that when I replaced the converter, the LNK304 started working for a while, but my question concerns the main switch attached in the photo.
    Is he supposed to connect on these two tracks, because nothing is happening on one of them. The question seems ridiculous, but I would like to be sure, because maybe there is a deal in it. Thank you for any suggestions.
    Electrolux ESL 65070 Dishwasher Not Turning On: Main Switch & Converter LNK304 IssuesWP_2017020...54_Pro.jpg (409.5 kB)You must be logged in to download this attachment.
  • #2 16834361
    grlng0
    Hello, the same thing happened to my dishwasher (same model) today ... How did the story of your fault end? What was the reason?
    Thanks and regards.
  • #3 16835773
    Trull
    Help: 138
    Rate: 600
    Apart from the inverter, the capacitors at the power input must be replaced, in this case 10 uF / 400V. High probability of repeated burning of the converter or damage to the choke at the power input (mechanical damage due to the tight housing during assembly or disassembly of the board). As for the switch, the second lead is auto-off, i.e. the switching off electromagnet.
  • #4 16912706
    bruno55
    Rate: 41
    Hello !
    The dishwasher could not be successfully repaired, so it was scrapped. I close the topic
