Hello, I have a problem with the Honda 2.0 engine and the v-tec k20a4 more accurately throws the camshaft position sensor error. The sensor is operational, the second one and no changes. The car does not want to go idle, it smells of unburned fuel from the exhaust, after checking everything, I went to the timing and here is the problem. The exhaust shaft is worn out, but after setting the shaft on the mark on the pulley, the marks on the camshaft wheels do not match. My question is. Is it possible that the chain stretched so much that "the timing broke up" and does anyone have a description of the signs and timing blocking locations for this car? there are 5mm holes on the camshafts from the side of the rotation sensors. Do I understand correctly that they block the rollers? Of course, at the moment it is not possible to insert pins there because if one fits, the other does not.
mbohun
mbohun
Rate: 43
