Volkswagen Transporter t5 - the yellow indicator light with the engine symbol is
mirage6661 19263 4
  • #1 16290141
    mirage6661
    Welcome gentlemen. I have a problem with a yellow indicator with a motor symbol on it. It will describe in what circumstances it caught fire, so a rubber conduit came to the engine intake manifold due to damage to the clasp (damage to the collar on the collar that holds it, clasp). After an emergency repair on the road, consisting of sticking the adhesive tape with the adhesive tape (connection could be leaky) I continued to drive in such circumstances. The control light came on. I continued the ride to the nearest point where I bought a new cable and of course I put it on. After replacing the wire, the indicator lights up. I am asking for information on how you can turn it off, whether you can do it yourself, and if so, how. Do you have to go to the website to erase errors in your computer. Yours sincerely, Mirosław M.
  • #2 16290199
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    Buddy, it's best to connect to the ECU and check the error.
    If you are not interested in what was the reason, disconnect the battery for 15 seconds after trouble.
  • #3 16290200
    yezz
    Help: 7
    Rate: 117
    Just visit the car workshop and connect the car to the computer and clear the error.
  • #4 16290201
    szymitsu21
    Help: 343
    Rate: 1300
    You have to go to someone who has diagnostic equipment and will delete the ECU fault record.
  • #5 16290626
    mirage6661
    Thank you gentlemen for such quick hints. First screw up to disconnect battery as you wrote Mr. DARO31 if it does not help, I will go to the diagnostician
