VW Transporter T5 2.5 TDI 2005: No Charging, Charge Lamp Issue, Alternator Replacement & Wiring
Seweryn92 14154 3
  • #1 16848107
    Seweryn92
    Hello, I have a problem with charging in vw t5 2.5 tdi 2005.
    The alternator was replaced twice.
    The first time the rubber wheel driving him was broken.
    The second time, the replaced alternator did not charge, but the lamp was on. (The error was in a blown 175A fuse)
    After the exchange, he did not want to charge, but after a while he started and he was loading about 2 weeks.
    Now it is not charging and there is no light on the meter.
    I would need a diagram of the cables that go from the alternator.
    I will try to check if they are clear or not broken.
    Maybe someone will advise me if the cable goes directly to the meter.
  • #2 16848922
    pylos
    Level 30  
    Help: 151
    Rate: 410
    Hello. Probably brushes to check.
  • #3 16849011
    przem27
    Level 30  
    Help: 131
    Rate: 496
    Not going, Blue to the module under the steering wheel and white and yellow to the ECM
  • #4 16849304
    Seweryn92
    Thanks for the answers, but the alternator is bought, new, probably regenerated.
    And if the brushes had wine, the light should be on.
    I checked it and blue goes to this module on the right side of the accelerator pedal and checked the passage and there is a passage.
    A yellow and white went to such a computer under the battery and there is also a transition of yellow and white falls on the 64 pin of the larger cube of the computer.
    And here's the question
    In my opinion, blue turns on the lamp, but I do not know which cable comes from this module to the meter.?
    Is it possible to wake it up (if it works)?
