Renault Master 2012 2.3 126KM - EGR Pipe Replacement, Error P2425 IP1425, STOP Engine Light
darek640 17838 2
  • #1 16290314
    darek640
    Rate: 194
    I have a problem with 2,3 126 KM master
    . 2012 year
    The EGR pipe cracked and then the car drove about 1000 km, then the STOP engine light came on red, further on the trailer.
    After replacing the tube, I erased the errors, but after a while they reappeared.
    P 1425 error unknown (probably exhaust gas recirculation pump)
    P 2425 Exhaust gas recirculation bypass valve for high frequency
    I tried to adapt the egr and the radiator pump egr KTS and DELPHI but it did not help.
    I mention that the car fires and has the same power as before the fault.
    I wonder if you should not adapt these parts of CLIP.
    I will be grateful for the hint.
  • #2 16290375
    szymitsu21
    Help: 343
    Rate: 1300
    Read it with clip.
    I think you're looking for a bad one. The car is burning?
  • #3 16299189
    darek640
    Rate: 194
    Poor hint
    Subject is overwhelmed.
