Polaroid MID4X10 (MID1048PCE03.112) Application e.g. settings has been stopped
krzych131 6018 10
How can I fix a Polaroid MID4X10 tablet that makes every app and game crash with 'application has been stopped', and where can I find the correct firmware?
The first thing to do is verify the exact chipset and flash only firmware that matches it; this tablet exists in different versions, and the Rockchip RK3126 model should not use the Mediatek ROMs [#16294052][#16296681] If your unit is the RK3126/YK98VQ-rk3126-V2.1 version, one forum member reported firmware that works correctly except for the webcam [#17090019] As a simple software test before flashing, another suggestion was to hard reset from recovery, keep Wi‑Fi off, then disable Google Play automatic updates before logging in again, because a Play Store update can trigger similar crashes [#16291429]
  • #1 16290983
    krzych131
    Hello. I bought a new tablet Polaroid MID4X10 (MID1048PCE03.112) after starting an application, e.g. Google, this application turns on for a moment and the message Google application has been stopped. And this is the case with all applications and games, after restoring factory settings, updating all applications even after hard reset the symptoms are still the same. The system is loaded 4.4.4. There is no software update from the tablet. I can not find other suitable firmware for this model. The device is not usable in its current state. I would like to ask you for some information on a system that fits this model or other suggestions regarding the problem. I would be very grateful.
  • #2 16291429
    gradek83
    Help: 930
    Rate: 2104
    Do a hard reset from the recovery mode but do not turn on the wi-fi tablet after that, go to the settings google play store and turn off the automatic update turn on wi-fi log in to the google account after install what you want and check if these applications work, usually the problem occurs with because of the update of the google play store, which just such a message crashes, but for you it does not necessarily have to be the reason for checking, it will not hurt. However, if you decide to play with other ROMs, first make a copy of the DUMP system so that you have a chance to return to the stock firmware.
    Check what chipset you have this Mediatek or Rockchip tablet on
  • #3 16293089
    krzych131
    Thanks gradek83 for the suggestion. I will try and see if anything comes out of it.
    Added after 1 [hours] 38 [minutes]:
    To enter the play store settings, I must first connect to the internet, i.e. wi-fi, activate the google account, otherwise I will not turn on the play store and settings for automatic updates. Any ideas?
  • #4 16293457
    gradek83
    Help: 930
    Rate: 2104
    You set up a google account, i.e. you create an account on the tablet, then you turn off wi-fi and only then you enter the store
  • #5 16294032
    krzych131
    Thanks for the advice, but unfortunately still the same. I guess just uploading another software can help. I just can't find anything. I have to remove the hatch and see the components. If anyone knows where to find Soft, please give me the information. Thank you in advance.
    gradek83
    Help: 930
    Rate: 2104
    On the rodent, look for only first check which chipset you have tablet on.
    Alternatively, if you succeed, install Spec Device And test the device and upload the data to the server and give the link there will be the exact specification.
    You click on My spec Link and Unpublish net must then be turned on.
    http://specdevice.com/
  • #7 16296588
    krzych131
    Hello. To gradek83, I have a Rockchip RK3126 here, which you think is soft because there is no description on your rodent, before downloading and I have to buy a GB package. My model MID4X10, can you help dzię thank you in advance.
  • #8 16296681
    gradek83
    Help: 930
    Rate: 2104
    So, as I thought, you have a version with Rockchip, I have versions, both on Mediatek, so do not even download. I was looking for Rockchip but I haven't found anything yet.
  • #9 16296719
    krzych131
    Thanks anyway. If you have something, please contact me.
  • #10 17090019
    karolnbox
    Hello. I have firmware for this tablet based on the rk3126 chip and the YK98VQ-rk3126-V2.1 board. The only problem with this software is a non-working webcam, the rest works fine. If anyone needs this file please let me know.
  • #11 20173765
    jakaco
    hey do you still have this file?
The discussion revolves around issues faced by a user of the Polaroid MID4X10 (MID1048PCE03.112) tablet, specifically the persistent crashing of applications, including Google, despite attempts at factory resets and updates. Suggestions include performing a hard reset without Wi-Fi, disabling automatic updates in the Google Play Store, and checking the chipset (Rockchip RK3126) to find compatible firmware. Users share insights on locating firmware and mention a specific firmware version that works but has a non-functional webcam. The conversation highlights the challenges of finding suitable software for this model.
