[Solved] FIAT BRAVO 2 (2009, 1.4 Gasoline, 90 KM) - Inconsistent Interior Temperature Control
Domes7 22419 4
  • #1 16291939
    Domes7
    I have a strange problem with the blower in the car, it started in January when it was below 0 ^ C. The car with the climate control turned off, on an ordinary blower where I set the temperature 16-18 began to explode with hot air. Unfortunately, the temperature in the car on the blower is unbearable, the computer does not react at all to changing the air temperature settings, whether the setting of 16 or 20 degrees is hot air. Only when I let LO cool down is it cold. On longer routes outside the city sometimes cooler air flies but there is still a problem with the optimal temperature control (once warm and cold / lottery)
    Is this a malfunction of the interior temperature sensor or sunlight, or something else ?? The fluid in the radiator does not decrease, so I guess there is no problem there.
    The car has two-zone air conditioning (climatronic)
    FIAT BRAVO 2; year 2009; 1.4 gasoline engine; 90 KM
    magir
    Help: 128
    Rate: 379
    The problem lies in the flap drives in the air mixer or in the sensor.
    The worst part is that access to it is massacre.
  • #3 16292201
    Domes7
    only that the computer does not show any error, just when I led the car to an electrician, it did not heat up for a while, the computer showed that it did not show an error and I left ... I do not know who can help in this topic.
  • #4 16292327
    magir
    Help: 128
    Rate: 379
    Only whether it was diagnosing the air conditioner or the engine - these are two different computers and not every program supports it.
    https://www.youtube.com/watch?v=0OqJcF5CEGQ
    https://www.youtube.com/watch?v=L02--8LY6VI
    for this you need to have dedicated software.
    The Fiat service certainly has. ...... only these costs. Look for who else is online.
  • #5 17108835
    Domes7
    Replacement of the air damper control motor, very laborious replacement, everything had to be removed from the front to get to it, in an unauthorized service cost PLN 700
